Output multiplex RTSP stream
There should be only one RTSP server on each device. For your use-case, you may try to enable two RTSP sinks in config file and check if it works. Please refer to document for modifying config file:
DeepStream Reference Application - deepstream-app — DeepStream 6.1.1 Release documentation
