**• Hardware Platform (Jetson / GPU)**Jetson Nano
• DeepStream Version 5.1
• JetPack Version (valid for Jetson only) 4.5
• TensorRT Version 7.1
**• Issue Type( questions, new requirements, bugs)**Issue
**• How to reproduce the issue ?
I am using 4 same sources in deepstream_test3 example.
Output I get is not consistent across all the 4 batched output. One shows object detected while another doesn’t show anything at all. Is there any configuration I have not set correctly in this case?
For example in output below its showing object detected on one batch, in next frame it will show on other, its not consistent across all frames
