Description
I did some experiments to figure out how to use profilingVerbosity. Its said here: TensorRT/tools/Polygraphy/examples/cli/inspect/02_inspecting_a_tensorrt_engine at main · NVIDIA/TensorRT · GitHub that
NOTE:
--show layers
only works if the engine was built with aprofiling_verbosity
other thanNONE
. Higher verbosities make more per-layer information available.
I used an export script for experiments and added builderConfig->setProfilingVerbosity(nvinfer1::ProfilingVerbosity::kNONE);
When not using this line it should default to ProfilingVerbosity::kDefault
, which is LAYERS_ONLY.
However, I receive the same output of poloygraphy inspect model <path> --show layers
no matter what verbosity level I select:
[I] Loading plugin library: …/plugin
[I] Loading bytes from …/experiments/model.plan
[I] ==== TensorRT Engine ====
Name: Unnamed Network 0 | Explicit Batch Engine
---- 1 Engine Input(s) ----
{in1 [dtype=float32, shape=(-1, 3, 1000, 1000)]}
---- 2 Engine Output(s) ----
{out1 [dtype=float32, shape=(-1, 10, 1, 1)],
out2 [dtype=float32, shape=(-1, 60, 1, 1)]}
---- Memory ----
Device Memory: 27622800 bytes
---- 1 Profile(s) (4 Binding(s) Each) ----
- Profile: 0
Binding Index: 0 (Input) [Name: in1_1] | Shapes: min=(1, 3, 1000, 1000), opt=(8, 3, 1000, 1000), max=(12, 3, 1000, 1000)
Binding Index: 1 (Output) [Name: out1] | Shape: (-1, 10, 1, 1)]
Binding Index: 2 (Output) [Name: out2] | Shape: (-1, 60, 1, 1)]
---- 210 Layer(s) ----
My questions are:
- Is this intended? Is the shown information the at least required information of tensorrt to use the model?
- When delivering a model to a client, or uploading a model to the cloud, I’d like to make it as hard as possible to reverse engineer the architecture or the model. Therefore it would be nice to not show layer information. When using profilingVerbosity::kNONE, which information can be reverted exactly?
Environment
TensorRT Version: 8.0
