abella
March 7, 2025, 7:06pm
1
Info
Jetson Orin
Ubuntu 22.04
NVIDIA Tegra Orin
Deepstream 7.1.0
Jetpack 6.1
Q
I’m trying to output the pipeline to a second display/monitor. I tried the alternatives mentioned in this post: Output into Second Display/Monitor - General Discussion - GStreamer Discourse . However, I haven’t succeeded. I also tried with the compiled jetson drm video sample (Jetson Linux API Reference: 08_video_dec_drm (Direct Rendering Manager) | NVIDIA Docs ). How could I manipulate this so I can render the video from the gstreamer/deepstream pipeline into a second display/monitor?
We support jetson_multimedia_api and gstreamer. Please make sure you have checked the document:
There are some examples in
Q: Is there any example of running RTSP streaming?
Q: Is there an example for running UDP streaming?
Q: I have a USB camera. How can I launch it on AGX Orin?
For further issues, please share a method to replicate the issue through gstreamer command, or either sample. We will set up developer kit and check.
Please try if setup the DISPLAY global environment helps.
For example:
$ export DISPLAY=:1
Then run the deepstream pipeline.
abella
March 10, 2025, 11:56am
8
Hi @AastaLLL ,
Thanks for responding. I’ve tried changing DISPLAY value to :1, :0.1, :2 and other variations. None of them have worked unfortunately. With export DISPLAY=:1
, the pipeline opens in the same monitor as in export DISPLAY=:0
Do you use a DP port with MST hub?
Could you share your setting with us?
(maybe a picture for your hardware setting)
abella
March 12, 2025, 1:30pm
10
Just to clarify. So are you able to see 2 GUI on your monitors when using that MST hub now?
BTW, HDMI is not possible to have 2 display output on Orin. Only DP with MST hub can.
abella
March 12, 2025, 1:53pm
12
Hi @WayneWWW ,
Exactly, I can see both GUI correctly. What I want is to choose the second monitor to show the video from the Deepstream pipeline. How could I do that?
By default we use single display in DeepStream SDK. You may try to set the properties and see if it can utilize second display:
[nv3dsink]
window-height : Height of window
flags: readable, writable
Unsigned Integer. Range: 0 - 2147483647 Default: 0
window-width : Width of window
window-x : X coordinate of window
window-y : Y coordinate of window
[nveglglessink]
Unsigned Integer. Range: 0 - 2147483647 Default: 10
[nvdrmvideosink]
conn-id : Sets CONN ID.
Integer. Range: 0 - 2147483647 Default: 2147483647
offset-x : Sets offset x
offset-y : Sets offset y
plane-id : Sets PLANE ID
Please note you would need to stop X11 and load DRM when using nvdrmvideosink :
Accelerated GStreamer — NVIDIA Jetson Linux Developer Guide
system
Closed
April 22, 2025, 12:43pm
16
