Because the hardware of the OV10640 camera we are using now does not match the PX2,
Need to modify the initial configuration of the MAX9286 register。
Try modifying the /px2/5050bL_SDK/DriveSDK/drive-t186ref-linux/samples/nvmedia/ext_dev_prgm/drv/isc_max9286 file
And compiled and generated libnv_extimgdev.so in nvmedia/ext_dev_prgm/img_dev
The question is, how can I make my modified configuration take effect in the PX2 ipp_raw program?
I moved to PX2 after ipp_raw was compiled.
And tried moving the newly compiled libnv_extimgdev.so to PX2 /usr/lib
But what is frustrating is that the new configuration has not taken effect. What am I missing?
I saw LDLIBS += -lnv_extimgdev in the IPP_RAW makefile.
It should be called here.
But how does the new libnv_extimgdev.so work in IPP_RAW?
Direct make does not take effect.
hello Calmcar-Bao,
sorry for late reply,
could you please check the sources under below.
and checking the *.setting.h for the initial configuration.
thanks
