hi:
we are trying to bring up the OV10640 camera module in the Orin development board with the FPD Link iii interface (UB960 and UB953). The driver loaded successfully on the l4t 34.1.1 release,but we dont find the /dev/video node. the following figure shows the drive information:
Skew calibration is required if sensor or deserializer is using DPHY, and the output data rate is > 1.5Gbps. An initiation deskew signal should be sent by sensor or deserializer to perform the skew calibration. If the deskew signals is not sent, the receiver will stall, and the capture will time out. You can calculate the output data rate with the following equation:
Output data rate = (sensor or deserializer pixel clock in hertz) * (bits per pixel) / (number of CSI lanes)
