OV2311 Custom Driver Issues
You are getting CHANSEL_SHORT_FRAME, which is usually related to a mismatch of the format/frame-size sent by the camera against what is configured on the driver to be received.
You also got the CHANSEL_NOMATCH, which is expecting RAW10, but looks like the data received is not matching.
Could you double-check that the camera mode is being configured correctly? Also, could you check if it’s sending more metadata-lines than the defined on the device-tree (embedded_metadata_height)
Regards,
-Enrique
