Dear all,
Now I want to use ISP of tegra instead of ISP inside camera module so I decide to use OV4689 sensor.
Based on current OV5693 driver, I made OV4689 driver almost same. But now I can not capture or streaming anything.
This is the result when I run v4l2-compliance -d /dev/video0
Driver Info:
Driver name : tegra-video
Card type : vi-output-0, ov4689 6-0010
Bus info : platform:vi:0
Driver version: 3.10.96
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Compliance test for device /dev/video0 (not using libv4l2):
Required ioctls:
test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
test second video open: OK
test VIDIOC_G/S_PRIORITY: OK
Debug ioctls:
test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
test VIDIOC_LOG_STATUS: OK (Not Supported)
Input ioctls:
test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
test VIDIOC_ENUMAUDIO: OK (Not Supported)
test VIDIOC_G/S/ENUMINPUT: OK
test VIDIOC_G/S_AUDIO: OK (Not Supported)
Inputs: 1 Audio Inputs: 0 Tuners: 0
Output ioctls:
test VIDIOC_G/S_MODULATOR: OK (Not Supported)
test VIDIOC_ENUMAUDOUT: OK (Not Supported)
test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
test VIDIOC_G/S_AUDOUT: OK (Not Supported)
Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
test VIDIOC_G/S_EDID: OK (Not Supported)
Test input 0:
Control ioctls:
test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK
test VIDIOC_QUERYCTRL: OK
test VIDIOC_G/S_CTRL: OK
test VIDIOC_G/S/TRY_EXT_CTRLS: OK
test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK
test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
Standard Controls: 1 Private Controls: 7
Format ioctls:
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
test VIDIOC_G/S_PARM: OK (Not Supported)
test VIDIOC_G_FBUF: OK (Not Supported)
test VIDIOC_G_FMT: OK
test VIDIOC_TRY_FMT: OK
test VIDIOC_S_FMT: OK
test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
fail: v4l2-test-formats.cpp(1257): doioctl(node, VIDIOC_G_SELECTION, &sel)
fail: v4l2-test-formats.cpp(1270): testLegacyCrop(node)
test Cropping: FAIL
test Composing: OK (Not Supported)
test Scaling: OK (Not Supported)
Codec ioctls:
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls:
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: OK
test VIDIOC_EXPBUF: OK
Test input 0:
Total: 42, Succeeded: 41, Failed: 1, Warnings: 0
When I try to capture with this command
gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=1 ! "video/x-bayer, format=rggb, width=1920, height=1080" ! filesink location=test_1920x1080.bayer
Then the result like this
[ 799.576029] [vunguyen] ov4689_power_on
[ 799.647349] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:1178b0, lanes:300000
[ 799.847400] video4linux video0: frame start syncpt timeout!0
[ 800.057478] video4linux video0: frame start syncpt timeout!0
[ 800.072565] [vunguyen] ov4689_power_off
If I use Nvcamerasrc :
DISPLAY=:0 gst-launch-1.0 nvcamerasrc sensor-id=0 fpsRange="30 30" ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! nvegltransform ! nveglglessink -e
then
[ 935.055408] [vunguyen] ov4689_power_on
[ 935.059499] [vunguyen] ov4689_power_off
[ 935.083958] [vunguyen] ov4689_power_on
[ 935.087741] [vunguyen] ov4689_power_off
[ 935.092157] [vunguyen] ov4689_power_on
[ 935.095952] [vunguyen] ov4689_power_off
[ 935.100004] [vunguyen] ov4689_power_on
[ 935.103827] [vunguyen] ov4689_power_off
[ 935.125978] pgd = ffffffc0a8b8a000
[ 935.129509] [00000000] *pgd=000000016debf003, *pmd=0000000000000000
[ 935.135929] Library at 0x40322c: 0x400000 /usr/sbin/nvcamera-daemon
[ 935.142338] Library at 0x403228: 0x400000 /usr/sbin/nvcamera-daemon
[ 935.148629] vdso base = 0x7fabb69000
Thanks and Best Regards,
Vu Nguyen
