OV9281 support
I’m trying to get the OV9281 camera to work using the 5.10.65-tegra kernel (using NVidia’s nv_ov9281.c driver).
My device-tree isn’t working yet, but also I’m not clear why we need to specify so many mode details in the DTS modeX {} node, when the V4L2 camera driver for this specific camera should be setting these values in the first place as they are a property of the hardware and / or many of those values depend on how that driver programs the hardware, e.g. line length, pixel format, or pixel bit depth, etc.
Specifically, I am using;
v4l2-ctl --set-fmt-video=width=1280,height=800,pixelformat=RG10 --stream-mmap --stream-count=1 -d /dev/video0 --stream-to=capture.raw
but that gives me the following kernel messages:
[ 2063.939488] bwmgr API not supported
[ 2063.987540] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 32
[ 2064.013505] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 2, flags: 0, err_data 13
1072
[ 2064.030077] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 3, flags: 0, err_data 13
1072
(all frames are being discarded, my capture.raw file remains at a size of 0 bytes).
I’ve attached the DTS currently in use, and would greatly appreciate any input / pointers please.
Thanks,
JJ
test.dts (7.0 KB)
  1. dump the device tree to check if the context as your expect due to your test device tree use the overlay.
  2. Get the trace log to check.
https://elinux.org/Jetson/l4t/Camera_BringUp
Hi Shane,
Thank you for your comments.
Regarding 1), I have checked this to be all as expected before posting.
Regarding 2), I’m again running
and here are the results when
a) boosting the clock (which only gives timeouts in the kernel log and lots of missed frames):
[  408.423248] bwmgr API not supported
[  408.457627] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 262144
[  411.100491] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  411.100760] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  411.101910] (NULL device *): vi_capture_control_message: NULL VI channel received
[  411.102152] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  411.102469] (NULL device *): vi_capture_control_message: NULL VI channel received
[  411.102711] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[  411.103339] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  411.125619] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 162, flags: 0, err_data 262144
[  413.628502] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
and b) enabling tracing (without boosting the clock):
    kworker/4:12-220     [004] ....   248.960497: rtcpu_string: tstamp:8306613650 id:0x04010000 str:"VM0 deactivating."
        v4l2-ctl-2301    [004] ....   260.936878: tegra_channel_open: vi-output, ov9281 2-0060
        v4l2-ctl-2301    [004] ....   260.939694: tegra_channel_set_power: ov9281 2-0060 : 0x1
        v4l2-ctl-2301    [004] ....   260.939702: camera_common_s_power: status : 0x1
        v4l2-ctl-2301    [004] ....   260.946157: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-2301    [004] ....   260.946160: csi_s_power: enable : 0x1
        v4l2-ctl-2301    [000] ....   260.947803: tegra_channel_capture_setup: vnc_id 0 W 1280 H 800 fmt c4
        v4l2-ctl-2301    [000] ....   260.966877: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-2301    [000] ....   260.983942: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-2301    [000] ....   260.983944: csi_s_stream: enable : 0x1
        v4l2-ctl-2301    [000] ....   260.984265: tegra_channel_set_stream: ov9281 2-0060 : 0x1
    kworker/4:12-220     [004] ....   261.004953: rtcpu_string: tstamp:8682522677 id:0x04010000 str:"VM0 activating."
    kworker/4:12-220     [004] ....   261.004972: rtcpu_vinotify_event: tstamp:8683320208 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:277854264704 data:0xc55cff0010000000
    kworker/4:12-220     [004] ....   261.004976: rtcpu_vinotify_event: tstamp:8683320385 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:277854271840 data:0x0000000031000001
    kworker/4:12-220     [004] ....   261.004979: rtcpu_vinotify_event: tstamp:8683320583 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:277854332960 data:0xc55cfc0010000000
    kworker/4:12-220     [004] ....   261.004982: rtcpu_vinotify_event: tstamp:8683320756 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:277854340192 data:0x0000000031000002
    kworker/4:12-220     [004] ....   261.060421: rtcpu_nvcsi_intr: tstamp:8684152554 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060430: rtcpu_nvcsi_intr: tstamp:8684152554 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
    kworker/4:12-220     [004] ....   261.060434: rtcpu_nvcsi_intr: tstamp:8684153304 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
    kworker/4:12-220     [004] ....   261.060436: rtcpu_nvcsi_intr: tstamp:8684158337 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060439: rtcpu_nvcsi_intr: tstamp:8684158337 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060442: rtcpu_nvcsi_intr: tstamp:8684161401 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060445: rtcpu_nvcsi_intr: tstamp:8684161893 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
    kworker/4:12-220     [004] ....   261.060447: rtcpu_nvcsi_intr: tstamp:8684165076 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060451: rtcpu_nvcsi_intr: tstamp:8684168472 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060454: rtcpu_nvcsi_intr: tstamp:8684171610 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060456: rtcpu_nvcsi_intr: tstamp:8684174468 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060459: rtcpu_nvcsi_intr: tstamp:8684177581 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060461: rtcpu_nvcsi_intr: tstamp:8684180433 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060464: rtcpu_nvcsi_intr: tstamp:8684183544 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060467: rtcpu_nvcsi_intr: tstamp:8684186421 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060469: rtcpu_nvcsi_intr: tstamp:8684186908 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
    kworker/4:12-220     [004] ....   261.060471: rtcpu_nvcsi_intr: tstamp:8684190092 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060474: rtcpu_nvcsi_intr: tstamp:8684192941 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060476: rtcpu_nvcsi_intr: tstamp:8684196063 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060478: rtcpu_nvcsi_intr: tstamp:8684199192 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060480: rtcpu_nvcsi_intr: tstamp:8684202050 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060483: rtcpu_nvcsi_intr: tstamp:8684205166 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060485: rtcpu_nvcsi_intr: tstamp:8684208297 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060487: rtcpu_nvcsi_intr: tstamp:8684211151 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060490: rtcpu_nvcsi_intr: tstamp:8684214261 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060493: rtcpu_nvcsi_intr: tstamp:8684217129 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060495: rtcpu_nvcsi_intr: tstamp:8684217620 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
    kworker/4:12-220     [004] ....   261.060497: rtcpu_nvcsi_intr: tstamp:8684220804 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060499: rtcpu_nvcsi_intr: tstamp:8684223658 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060502: rtcpu_nvcsi_intr: tstamp:8684226775 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060504: rtcpu_nvcsi_intr: tstamp:8684229624 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060506: rtcpu_nvcsi_intr: tstamp:8684232749 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060508: rtcpu_nvcsi_intr: tstamp:8684235601 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060511: rtcpu_nvcsi_intr: tstamp:8684238720 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060514: rtcpu_nvcsi_intr: tstamp:8684241575 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060516: rtcpu_nvcsi_intr: tstamp:8684244692 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060518: rtcpu_nvcsi_intr: tstamp:8684247518 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060521: rtcpu_nvcsi_intr: tstamp:8684250675 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060523: rtcpu_nvcsi_intr: tstamp:8684253520 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060525: rtcpu_nvcsi_intr: tstamp:8684256635 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060528: rtcpu_nvcsi_intr: tstamp:8684259480 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060530: rtcpu_nvcsi_intr: tstamp:8684262612 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060532: rtcpu_nvcsi_intr: tstamp:8684265468 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060534: rtcpu_nvcsi_intr: tstamp:8684268576 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060536: rtcpu_nvcsi_intr: tstamp:8684271417 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060539: rtcpu_nvcsi_intr: tstamp:8684274551 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060541: rtcpu_nvcsi_intr: tstamp:8684277406 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060543: rtcpu_nvcsi_intr: tstamp:8684280522 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060545: rtcpu_nvcsi_intr: tstamp:8684283634 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060548: rtcpu_nvcsi_intr: tstamp:8684286521 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060550: rtcpu_nvcsi_intr: tstamp:8684287006 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
    kworker/4:12-220     [004] ....   261.060552: rtcpu_nvcsi_intr: tstamp:8684290193 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060554: rtcpu_nvcsi_intr: tstamp:8684293047 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060557: rtcpu_nvcsi_intr: tstamp:8684296164 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060559: rtcpu_nvcsi_intr: tstamp:8684299018 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060561: rtcpu_nvcsi_intr: tstamp:8684302151 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060564: rtcpu_nvcsi_intr: tstamp:8684305001 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060566: rtcpu_nvcsi_intr: tstamp:8684308092 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060568: rtcpu_nvcsi_intr: tstamp:8684310932 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060571: rtcpu_nvcsi_intr: tstamp:8684314082 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060573: rtcpu_nvcsi_intr: tstamp:8684316934 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060575: rtcpu_nvcsi_intr: tstamp:8684320049 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060577: rtcpu_nvcsi_intr: tstamp:8684323180 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060580: rtcpu_nvcsi_intr: tstamp:8684323686 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060582: rtcpu_nvcsi_intr: tstamp:8684323686 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060584: rtcpu_nvcsi_intr: tstamp:8684326875 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060587: rtcpu_nvcsi_intr: tstamp:8684329721 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060589: rtcpu_nvcsi_intr: tstamp:8684332847 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060591: rtcpu_nvcsi_intr: tstamp:8684335700 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060593: rtcpu_nvcsi_intr: tstamp:8684338830 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060596: rtcpu_nvcsi_intr: tstamp:8684341679 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060598: rtcpu_nvcsi_intr: tstamp:8684344791 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060600: rtcpu_nvcsi_intr: tstamp:8684347637 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060602: rtcpu_nvcsi_intr: tstamp:8684350763 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060604: rtcpu_nvcsi_intr: tstamp:8684353616 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060607: rtcpu_nvcsi_intr: tstamp:8684356736 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060609: rtcpu_nvcsi_intr: tstamp:8684359581 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060611: rtcpu_nvcsi_intr: tstamp:8684362706 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060613: rtcpu_nvcsi_intr: tstamp:8684365556 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060615: rtcpu_nvcsi_intr: tstamp:8684368680 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060618: rtcpu_nvcsi_intr: tstamp:8684371549 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060620: rtcpu_nvcsi_intr: tstamp:8684372030 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
    kworker/4:12-220     [004] ....   261.060622: rtcpu_nvcsi_intr: tstamp:8684375218 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060624: rtcpu_nvcsi_intr: tstamp:8684378064 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
    kworker/4:12-220     [004] ....   261.060630: rtcpu_vinotify_event: tstamp:8684406029 cch:0 vi:0 tag:FS channel:0x00 frame:1 vi_tstamp:277892688096 data:0x0000000100000010
    kworker/4:12-220     [004] ....   261.060633: rtcpu_vinotify_event: tstamp:8684406172 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:277892688160 data:0x0000000800000000
    kworker/4:12-220     [004] ....   261.060636: rtcpu_vinotify_event: tstamp:8684406331 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:277892879520 data:0x0000000000000001
    kworker/4:12-220     [004] ....   261.060638: rtcpu_vinotify_event: tstamp:8684406466 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:1 vi_tstamp:277892888352 data:0x0000000008020001
    kworker/4:12-220     [004] ....   261.060640: rtcpu_vinotify_event: tstamp:8684406619 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:1 vi_tstamp:277892889120 data:0x0000000000000200
    kworker/4:12-220     [004] ....   261.060643: rtcpu_vinotify_event: tstamp:8684406754 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:1 vi_tstamp:277892961856 data:0x0000000001020001
    kworker/4:12-220     [004] ....   261.060645: rtcpu_nvcsi_intr: tstamp:8684670817 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060648: rtcpu_nvcsi_intr: tstamp:8684670817 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
    kworker/4:12-220     [004] ....   261.060650: rtcpu_nvcsi_intr: tstamp:8684670817 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060656: rtcpu_vinotify_error: tstamp:8684675892 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:1 vi_tstamp:277909259232 data:0x00000002000000a0
    kworker/4:12-220     [004] ....   261.060664: rtcpu_vinotify_event: tstamp:8684677188 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:1 vi_tstamp:277909259232 data:0x00000002000000a0
    kworker/4:12-220     [004] ....   261.060668: rtcpu_vinotify_event: tstamp:8684677321 cch:0 vi:0 tag:FS channel:0x00 frame:2 vi_tstamp:277909259232 data:0x0000000200000010
    kworker/4:12-220     [004] ....   261.060670: rtcpu_vinotify_event: tstamp:8684677474 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:1 vi_tstamp:277909259264 data:0x0004200001000000
    kworker/4:12-220     [004] ....   261.060672: rtcpu_vinotify_event: tstamp:8684677609 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:1 vi_tstamp:277909259264 data:0x0000200000000000
    kworker/4:12-220     [004] ....   261.060674: rtcpu_vinotify_event: tstamp:8684677760 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:277909259328 data:0x0000000800000000
    kworker/4:12-220     [004] ....   261.060677: rtcpu_vinotify_event: tstamp:8684677894 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:277909259328 data:0x0000000800000000
    kworker/4:12-220     [004] ....   261.060679: rtcpu_nvcsi_intr: tstamp:8684680547 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060682: rtcpu_nvcsi_intr: tstamp:8684680547 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060684: rtcpu_nvcsi_intr: tstamp:8684684532 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060686: rtcpu_nvcsi_intr: tstamp:8684684532 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060689: rtcpu_nvcsi_intr: tstamp:8684688512 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060691: rtcpu_nvcsi_intr: tstamp:8684688512 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060693: rtcpu_nvcsi_intr: tstamp:8684692493 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060695: rtcpu_nvcsi_intr: tstamp:8684692493 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060698: rtcpu_nvcsi_intr: tstamp:8684696474 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060700: rtcpu_nvcsi_intr: tstamp:8684696474 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060702: rtcpu_nvcsi_intr: tstamp:8684700453 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060704: rtcpu_nvcsi_intr: tstamp:8684700453 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060707: rtcpu_nvcsi_intr: tstamp:8684704437 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060709: rtcpu_nvcsi_intr: tstamp:8684704437 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060711: rtcpu_nvcsi_intr: tstamp:8684708416 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060713: rtcpu_nvcsi_intr: tstamp:8684708416 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060716: rtcpu_nvcsi_intr: tstamp:8684712400 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060718: rtcpu_nvcsi_intr: tstamp:8684712400 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060720: rtcpu_nvcsi_intr: tstamp:8684716379 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060722: rtcpu_nvcsi_intr: tstamp:8684716379 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060724: rtcpu_nvcsi_intr: tstamp:8684720361 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060727: rtcpu_nvcsi_intr: tstamp:8684720361 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060729: rtcpu_nvcsi_intr: tstamp:8684724342 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060731: rtcpu_nvcsi_intr: tstamp:8684724342 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060733: rtcpu_nvcsi_intr: tstamp:8684728323 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060736: rtcpu_nvcsi_intr: tstamp:8684728323 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060738: rtcpu_nvcsi_intr: tstamp:8684732306 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060740: rtcpu_nvcsi_intr: tstamp:8684732306 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060742: rtcpu_nvcsi_intr: tstamp:8684741121 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060744: rtcpu_nvcsi_intr: tstamp:8684741121 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060747: rtcpu_nvcsi_intr: tstamp:8684745102 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060749: rtcpu_nvcsi_intr: tstamp:8684745102 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060751: rtcpu_nvcsi_intr: tstamp:8684749084 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060753: rtcpu_nvcsi_intr: tstamp:8684749084 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060756: rtcpu_nvcsi_intr: tstamp:8684753064 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060758: rtcpu_nvcsi_intr: tstamp:8684753064 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060760: rtcpu_nvcsi_intr: tstamp:8684757046 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060762: rtcpu_nvcsi_intr: tstamp:8684757046 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060765: rtcpu_nvcsi_intr: tstamp:8684761025 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060767: rtcpu_nvcsi_intr: tstamp:8684761025 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060770: rtcpu_nvcsi_intr: tstamp:8684765009 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060772: rtcpu_nvcsi_intr: tstamp:8684765009 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060774: rtcpu_nvcsi_intr: tstamp:8684768990 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060776: rtcpu_nvcsi_intr: tstamp:8684768990 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060779: rtcpu_nvcsi_intr: tstamp:8684772970 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060781: rtcpu_nvcsi_intr: tstamp:8684772970 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060783: rtcpu_nvcsi_intr: tstamp:8684776951 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060785: rtcpu_nvcsi_intr: tstamp:8684776951 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060788: rtcpu_nvcsi_intr: tstamp:8684780933 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060790: rtcpu_nvcsi_intr: tstamp:8684780933 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060792: rtcpu_nvcsi_intr: tstamp:8684784914 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060794: rtcpu_nvcsi_intr: tstamp:8684784914 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060797: rtcpu_nvcsi_intr: tstamp:8684788896 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060799: rtcpu_nvcsi_intr: tstamp:8684788896 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060801: rtcpu_nvcsi_intr: tstamp:8684792877 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060803: rtcpu_nvcsi_intr: tstamp:8684792877 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060806: rtcpu_nvcsi_intr: tstamp:8684801693 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060808: rtcpu_nvcsi_intr: tstamp:8684801693 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060810: rtcpu_nvcsi_intr: tstamp:8684805673 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060812: rtcpu_nvcsi_intr: tstamp:8684805673 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060814: rtcpu_nvcsi_intr: tstamp:8684809653 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060816: rtcpu_nvcsi_intr: tstamp:8684809653 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060819: rtcpu_nvcsi_intr: tstamp:8684813635 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060821: rtcpu_nvcsi_intr: tstamp:8684813635 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060823: rtcpu_nvcsi_intr: tstamp:8684817618 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060825: rtcpu_nvcsi_intr: tstamp:8684817618 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060828: rtcpu_nvcsi_intr: tstamp:8684821598 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060830: rtcpu_nvcsi_intr: tstamp:8684821598 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060832: rtcpu_nvcsi_intr: tstamp:8684825579 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060834: rtcpu_nvcsi_intr: tstamp:8684825579 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060836: rtcpu_nvcsi_intr: tstamp:8684829561 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060839: rtcpu_nvcsi_intr: tstamp:8684829561 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060841: rtcpu_nvcsi_intr: tstamp:8684833541 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060844: rtcpu_nvcsi_intr: tstamp:8684833541 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060846: rtcpu_nvcsi_intr: tstamp:8684837524 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060848: rtcpu_nvcsi_intr: tstamp:8684837524 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060850: rtcpu_nvcsi_intr: tstamp:8684841505 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060852: rtcpu_nvcsi_intr: tstamp:8684841505 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060855: rtcpu_nvcsi_intr: tstamp:8684845487 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060857: rtcpu_nvcsi_intr: tstamp:8684845487 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060859: rtcpu_nvcsi_intr: tstamp:8684849468 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060861: rtcpu_nvcsi_intr: tstamp:8684849468 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060864: rtcpu_nvcsi_intr: tstamp:8684853450 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060866: rtcpu_nvcsi_intr: tstamp:8684853450 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060868: rtcpu_nvcsi_intr: tstamp:8684866244 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060870: rtcpu_nvcsi_intr: tstamp:8684866244 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060873: rtcpu_nvcsi_intr: tstamp:8684870227 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060875: rtcpu_nvcsi_intr: tstamp:8684870227 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060877: rtcpu_nvcsi_intr: tstamp:8684874207 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060879: rtcpu_nvcsi_intr: tstamp:8684874207 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060881: rtcpu_nvcsi_intr: tstamp:8684878187 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060884: rtcpu_nvcsi_intr: tstamp:8684878187 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060886: rtcpu_nvcsi_intr: tstamp:8684882173 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060888: rtcpu_nvcsi_intr: tstamp:8684882173 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060890: rtcpu_nvcsi_intr: tstamp:8684886152 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060892: rtcpu_nvcsi_intr: tstamp:8684886152 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060895: rtcpu_nvcsi_intr: tstamp:8684890133 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060897: rtcpu_nvcsi_intr: tstamp:8684890133 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060899: rtcpu_nvcsi_intr: tstamp:8684894115 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060901: rtcpu_nvcsi_intr: tstamp:8684894115 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060904: rtcpu_nvcsi_intr: tstamp:8684897898 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
    kworker/4:12-220     [004] ....   261.060906: rtcpu_nvcsi_intr: tstamp:8684897898 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
    kworker/4:12-220     [004] ....   261.060909: rtcpu_vinotify_event: tstamp:8685164734 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:2 vi_tstamp:277909450592 data:0x0000000000000001
    kworker/4:12-220     [004] ....   261.060914: rtcpu_vinotify_event: tstamp:8685164873 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:2 vi_tstamp:277909470688 data:0x0000000008020002
    kworker/4:12-220     [004] ....   261.060916: rtcpu_vinotify_event: tstamp:8685165028 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:277909750080 data:0xc55cff0010000000
    kworker/4:12-220     [004] ....   261.060919: rtcpu_vinotify_event: tstamp:8685165164 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:277909794496 data:0x0000000031000003
    kworker/4:12-220     [004] ....   261.060921: rtcpu_vinotify_event: tstamp:8685165318 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:2 vi_tstamp:277916731648 data:0x0000000000330200
    kworker/4:12-220     [004] ....   261.060923: rtcpu_vinotify_event: tstamp:8685165451 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:2 vi_tstamp:277916772256 data:0x0000000001020002
    kworker/4:12-220     [004] ....   261.060926: rtcpu_nvcsi_intr: tstamp:8685193726 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x0000000c
    kworker/4:12-220     [004] ....   261.060929: rtcpu_nvcsi_intr: tstamp:8685193726 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x0000000c
    kworker/4:12-220     [004] ....   261.060931: rtcpu_nvcsi_intr: tstamp:8685197374 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060934: rtcpu_nvcsi_intr: tstamp:8685197374 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060937: rtcpu_vinotify_error: tstamp:8685198733 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:277925830304 data:0x00000003000000a0
    kworker/4:12-220     [004] ....   261.060939: rtcpu_nvcsi_intr: tstamp:8685201316 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060941: rtcpu_nvcsi_intr: tstamp:8685201316 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060944: rtcpu_vinotify_event: tstamp:8685202072 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:277925830304 data:0x00000003000000a0
    kworker/4:12-220     [004] ....   261.060946: rtcpu_vinotify_event: tstamp:8685202209 cch:0 vi:0 tag:FS channel:0x00 frame:3 vi_tstamp:277925830304 data:0x0000000300000010
    kworker/4:12-220     [004] ....   261.060949: rtcpu_vinotify_event: tstamp:8685202366 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:2 vi_tstamp:277925830336 data:0x0034200001000000
    kworker/4:12-220     [004] ....   261.060951: rtcpu_vinotify_event: tstamp:8685202505 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:2 vi_tstamp:277925830336 data:0x0000200000000000
    kworker/4:12-220     [004] ....   261.060953: rtcpu_vinotify_event: tstamp:8685202663 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:277925830400 data:0x0000000800000000
    kworker/4:12-220     [004] ....   261.060955: rtcpu_vinotify_event: tstamp:8685202802 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:277925830432 data:0x0000000800000000
    kworker/4:12-220     [004] ....   261.060958: rtcpu_vinotify_event: tstamp:8685202956 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:3 vi_tstamp:277926021760 data:0x0000000000000001
    kworker/4:12-220     [004] ....   261.060960: rtcpu_vinotify_event: tstamp:8685203095 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:277926059680 data:0x0000000008020003
    kworker/4:12-220     [004] ....   261.060962: rtcpu_vinotify_event: tstamp:8685203249 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:3 vi_tstamp:277926031360 data:0x0000000000000200
    kworker/4:12-220     [004] ....   261.060964: rtcpu_vinotify_event: tstamp:8685203386 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:277926133184 data:0x0000000001020003
    kworker/4:12-220     [004] ....   261.060967: rtcpu_nvcsi_intr: tstamp:8685204939 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060969: rtcpu_nvcsi_intr: tstamp:8685204939 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060971: rtcpu_nvcsi_intr: tstamp:8685208918 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060974: rtcpu_nvcsi_intr: tstamp:8685208918 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060976: rtcpu_nvcsi_intr: tstamp:8685212900 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060978: rtcpu_nvcsi_intr: tstamp:8685212900 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060980: rtcpu_nvcsi_intr: tstamp:8685216881 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060982: rtcpu_nvcsi_intr: tstamp:8685216881 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060985: rtcpu_nvcsi_intr: tstamp:8685229678 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060987: rtcpu_nvcsi_intr: tstamp:8685229678 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060989: rtcpu_nvcsi_intr: tstamp:8685233659 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060991: rtcpu_nvcsi_intr: tstamp:8685233659 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060993: rtcpu_nvcsi_intr: tstamp:8685237638 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060995: rtcpu_nvcsi_intr: tstamp:8685237638 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
    kworker/4:12-220     [004] ....   261.060998: rtcpu_nvcsi_intr: tstamp:8685241622 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
this continues forever until v4l2-ctrl is stopped.
At the same time, the kernel prints the following messages:
[  260.945475] ov9281 2-0060: Using default I2C address 0x60
[  260.978058] bwmgr API not supported
[  261.008897] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 512
[  261.029411] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 2, flags: 0, err_data 512
[  261.038798] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 3, flags: 0, err_data 512
[  263.399053] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 145, flags: 0, err_data 512
[  263.424997] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 146, flags: 0, err_data 131072
Can you help me interpret the trace please?
JJ
Boost the clocks to try. Due to FIFO full error.
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
Thank you Shane.
Please see logs for running following command with clocks boosted as per your suggestion:
The trace logs now shows:
     kworker/4:1-74      [004] ....   259.044184: rtcpu_string: tstamp:8621324996 id:0x04010000 str:"VM0 deactivating."
        v4l2-ctl-2376    [000] ....   260.057697: tegra_channel_open: vi-output, ov9281 2-0060
        v4l2-ctl-2376    [000] ....   260.059776: tegra_channel_set_power: ov9281 2-0060 : 0x1
        v4l2-ctl-2376    [000] ....   260.059781: camera_common_s_power: status : 0x1
        v4l2-ctl-2376    [000] ....   260.065168: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-2376    [000] ....   260.065170: csi_s_power: enable : 0x1
        v4l2-ctl-2376    [000] ....   260.065217: tegra_channel_capture_setup: vnc_id 0 W 1280 H 800 fmt c4
        v4l2-ctl-2376    [001] ....   260.079031: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-2376    [001] ....   260.082529: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-2376    [001] ....   260.082533: csi_s_stream: enable : 0x1
        v4l2-ctl-2376    [001] ....   260.082820: tegra_channel_set_stream: ov9281 2-0060 : 0x1
     kworker/4:1-74      [004] ....   260.107738: rtcpu_string: tstamp:8654934313 id:0x04010000 str:"VM0 activating."
     kworker/4:1-74      [004] ....   260.107757: rtcpu_vinotify_event: tstamp:8655537286 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276967763104 data:0xc55cff0010000000
     kworker/4:1-74      [004] ....   260.107762: rtcpu_vinotify_event: tstamp:8655537443 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276967770272 data:0x0000000031000001
     kworker/4:1-74      [004] ....   260.107765: rtcpu_vinotify_event: tstamp:8655537599 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276967815008 data:0xc55cfc0010000000
     kworker/4:1-74      [004] ....   260.107768: rtcpu_vinotify_event: tstamp:8655537733 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:276967822272 data:0x0000000031000002
     kworker/4:1-74      [004] ....   260.163741: rtcpu_vinotify_event: tstamp:8656188234 cch:0 vi:0 tag:FS channel:0x00 frame:1 vi_tstamp:276992225728 data:0x0000000100000010
     kworker/4:1-74      [004] ....   260.163751: rtcpu_vinotify_event: tstamp:8656188377 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:276992225728 data:0x0000000800000000
     kworker/4:1-74      [004] ....   260.163755: rtcpu_vinotify_event: tstamp:8656188533 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:276992416992 data:0x0000000000000001
     kworker/4:1-74      [004] ....   260.163758: rtcpu_vinotify_event: tstamp:8656188671 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:1 vi_tstamp:276992418336 data:0x0000000008020001
     kworker/4:1-74      [004] ....   260.163761: rtcpu_vinotify_event: tstamp:8656513821 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:276999695808 data:0x00000000031f0002
     kworker/4:1-74      [004] ....   260.163764: rtcpu_vinotify_event: tstamp:8656513980 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:276999696384 data:0x0000000000000000
     kworker/4:1-74      [004] ....   260.163767: rtcpu_vinotify_event: tstamp:8656514138 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:1 vi_tstamp:276999698400 data:0x0000000002020001
     kworker/4:1-74      [004] ....   260.163770: rtcpu_vinotify_event: tstamp:8656514273 cch:0 vi:0 tag:FE channel:0x00 frame:1 vi_tstamp:276999696672 data:0x0000000100000020
     kworker/4:1-74      [004] ....   260.163772: rtcpu_vinotify_event: tstamp:8656514425 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:1 vi_tstamp:276999696672 data:0x0000200000000000
     kworker/4:1-74      [004] ....   260.163775: rtcpu_vinotify_event: tstamp:8656514559 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:1 vi_tstamp:276999709440 data:0x0000000001020001
     kworker/4:1-74      [004] ....   260.163778: rtcpu_vinotify_event: tstamp:8656514712 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:276999696704 data:0x0000000800000000
     kworker/4:1-74      [004] ....   260.163780: rtcpu_vinotify_event: tstamp:8656525519 cch:0 vi:0 tag:FS channel:0x00 frame:2 vi_tstamp:277008796800 data:0x0000000200000010
     kworker/4:1-74      [004] ....   260.163783: rtcpu_vinotify_event: tstamp:8656839245 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:277008796832 data:0x0000000800000000
     kworker/4:1-74      [004] ....   260.163785: rtcpu_vinotify_event: tstamp:8656839380 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:2 vi_tstamp:277008988096 data:0x0000000000000001
     kworker/4:1-74      [004] ....   260.163788: rtcpu_vinotify_event: tstamp:8656839536 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:2 vi_tstamp:277016266912 data:0x00000000031f0002
     kworker/4:1-74      [004] ....   260.163790: rtcpu_vinotify_event: tstamp:8656839671 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:2 vi_tstamp:277016267520 data:0x0000000000000000
     kworker/4:1-74      [004] ....   260.163793: rtcpu_vinotify_event: tstamp:8656839824 cch:0 vi:0 tag:FE channel:0x00 frame:2 vi_tstamp:277016267808 data:0x0000000200000020
     kworker/4:1-74      [004] ....   260.163795: rtcpu_vinotify_event: tstamp:8656839957 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:2 vi_tstamp:277016267808 data:0x0000200000000000
     kworker/4:1-74      [004] ....   260.163797: rtcpu_vinotify_event: tstamp:8656840110 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:277016267808 data:0x0000000800000000
     kworker/4:1-74      [004] ....   260.163802: rtcpu_vinotify_error: tstamp:8657049440 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:3 vi_tstamp:277025559200 data:0x0000000000000569
     kworker/4:1-74      [004] ....   260.163805: rtcpu_vinotify_event: tstamp:8657164913 cch:0 vi:0 tag:FS channel:0x00 frame:3 vi_tstamp:277025367936 data:0x0000000300000010
     kworker/4:1-74      [004] ....   260.163808: rtcpu_vinotify_event: tstamp:8657165062 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:3 vi_tstamp:277025559200 data:0x0000000000000569
     kworker/4:1-74      [004] ....   260.163810: rtcpu_vinotify_event: tstamp:8657490419 cch:0 vi:0 tag:FE channel:0x00 frame:3 vi_tstamp:277032838912 data:0x0000000300000020
     kworker/4:1-74      [004] ....   260.163813: rtcpu_vinotify_error: tstamp:8657567285 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:4 vi_tstamp:277042130336 data:0x0000000000000569
     kworker/4:1-74      [004] ....   260.163815: rtcpu_vinotify_event: tstamp:8657815943 cch:0 vi:0 tag:FS channel:0x00 frame:4 vi_tstamp:277041939040 data:0x0000000400000010
     kworker/4:1-74      [004] ....   260.163818: rtcpu_vinotify_event: tstamp:8657816080 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:4 vi_tstamp:277042130336 data:0x0000000000000569
     kworker/4:1-74      [004] ....   260.163820: rtcpu_vinotify_event: tstamp:8657816232 cch:0 vi:0 tag:FE channel:0x00 frame:4 vi_tstamp:277049410048 data:0x0000000400000020
and kernel log shows:
[  260.082308] bwmgr API not supported
[  260.110692] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 262144
[  262.619705] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  262.620187] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  262.621392] (NULL device *): vi_capture_control_message: NULL VI channel received
[  262.621605] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  262.621906] (NULL device *): vi_capture_control_message: NULL VI channel received
[  262.622109] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[  262.622547] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  262.646192] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 154, flags: 0, err_data 262144
[  265.151667] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
It seems it manages to determine correct line length? But still isn’t happy about something (CHANSEL_SHORT_FRAME)?
Any ideas?
How much processing is happening here? I know the pixelformat is not Bayer10, but rather some grayscale 10 bit coming from the ov9281. At this stage I just want to confirm that we can receive / capture this ‘raw’ data. Is it a problem for the NVidia hardware that the format is different? I would still expect to be able to capture ‘garbage’ data.
JJ
Short frame tell the sensor output lines less than expect.
