Hi Shane,
Actually right now in my device-tree, under tegra-camera-platform below entries are done for modules:
modules {
module0 {
badge = “e33_topleft_P5V27C”;
position = “topleft”;
orientation = “0”;
drivernode0 {
/* Declare PCL support driver (classically known as guid) /
pcl_id = “v4l2_sensor”;
/ Driver v4l2 device name /
devname = “ov9732 7-0036”;
/ Declare the device-tree hierarchy to driver instance /
proc-device-tree = “/proc/device-tree/i2c@c250000/ov9732_f@36”;
drivernode1 {
/ Declare PCL support driver (classically known as guid) /
pcl_id = “v4l2_lens”;
proc-device-tree = “/proc/device-tree/e33_lens_ov9732@P5V27C/”;
module1 {
badge = “e33_centreright_P5V27C”;
position = “centerright”;
orientation = “0”;
drivernode0 {
devname = “ov9732 2-0036”;
proc-device-tree = “/proc/device-tree/i2c@3180000/ov9732_e@36”;
drivernode1 {
/ Declare PCL support driver (classically known as guid) */
So When i am running gst-launch with sensor-id=0 then module0 is capturing the videos and when i am using sensor-id=1 then module1 starts capturing but its not releasing the buffer and is stuck as below:
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 40
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1280 x 720 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 22000, max 358733000;
GST_ARGUS: Running with following settings:
Camera index = 1
Camera mode = 0
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
and in the dmesg, its trying to capture on all the three cameras as below
[ 86.156628] ov491 2-0024: ov491_open:
[ 86.158414] ov491 2-0024: ov491_power_on: power on
[ 86.158418] ov491 2-0024: ov491_power_on: Power ON success
[ 86.160290] ov491 2-0024: ov491_power_off: power off
[ 86.160295] ov491 2-0024: ov491_power_off: Power OFF success
[ 86.160866] ov9732 2-0036: ov9732_power_on: VVDN: power on
[ 86.170579] ov9732 2-0036: ov9732_power_on: Power ON success
[ 86.176423] ov9732 2-0036: ov9732_power_off: VVDN: power off
[ 86.184735] ov9732 7-0036: ov9732_power_on: VVDN: power on
[ 86.194441] ov9732 7-0036: ov9732_power_on: Power ON success
[ 86.200396] ov9732 7-0036: ov9732_power_off: VVDN: power off
[ 92.361935] tegra_camera_open: VVDN: tegra_camera_open Called
[ 92.392515] ov491 2-0024: ov491_power_on: power on
[ 92.392529] ov491 2-0024: ov491_power_on: Power ON success
[ 92.398405] ov491 2-0024: ov491_power_off: power off
[ 92.398411] ov491 2-0024: ov491_power_off: Power OFF success
[ 92.399094] ov9732 2-0036: ov9732_power_on: VVDN: power on
[ 92.408705] ov9732 2-0036: ov9732_power_on: Power ON success
[ 92.414486] ov9732 2-0036: ov9732_power_off: VVDN: power off
[ 92.424868] ov9732 7-0036: ov9732_power_on: VVDN: power on
[ 92.434456] ov9732 7-0036: ov9732_power_on: Power ON success
[ 92.440241] ov9732 7-0036: ov9732_power_off: VVDN: power off
[ 92.450600] ov491 2-0024: ov491_power_on: power on
[ 92.450603] ov491 2-0024: ov491_power_on: Power ON success
[ 92.450657] ov491 2-0024: ov491_power_off: power off
[ 92.450660] ov491 2-0024: ov491_power_off: Power OFF success
[ 92.451185] ov9732 2-0036: ov9732_power_on: VVDN: power on
[ 92.460819] ov9732 2-0036: ov9732_power_on: Power ON success
[ 92.466586] ov9732 2-0036: ov9732_power_off: VVDN: power off
[ 92.476930] ov9732 7-0036: ov9732_power_on: VVDN: power on
[ 92.486598] ov9732 7-0036: ov9732_power_on: Power ON success
[ 92.492570] ov9732 7-0036: ov9732_power_off: VVDN: power off
[ 92.518429] ov9732 7-0036: ov9732_power_on: VVDN: power on
[ 92.528178] ov9732 7-0036: ov9732_power_on: Power ON success
[ 92.534208] ov9732 7-0036: ov9732_power_off: VVDN: power off
[ 92.542957] ov9732 7-0036: ov9732_power_on: VVDN: power on
[ 92.552628] ov9732 7-0036: ov9732_power_on: Power ON success
[ 92.558451] ov9732 7-0036: ov9732_power_off: VVDN: power off
[ 92.566801] ov9732 7-0036: ov9732_power_on: VVDN: power on
[ 92.576529] ov9732 7-0036: ov9732_power_on: Power ON success
[ 92.582332] ov9732 7-0036: ov9732_power_off: VVDN: power off
[ 92.633351] ov9732 7-0036: ov9732_power_on: VVDN: power on
[ 92.642937] ov9732 7-0036: ov9732_power_on: Power ON success
[ 92.648916] ov9732 7-0036: ov9732_power_off: VVDN: power off
[ 92.662547] ov9732 2-0036: ov9732_power_on: VVDN: power on
[ 92.672245] ov9732 2-0036: ov9732_power_on: Power ON success
[ 92.678127] ov9732 2-0036: ov9732_power_off: VVDN: power off
[ 92.687246] ov9732 2-0036: ov9732_power_on: VVDN: power on
[ 92.697036] ov9732 2-0036: ov9732_power_on: Power ON success
[ 92.702875] ov9732 2-0036: ov9732_power_off: VVDN: power off
[ 92.711231] ov9732 2-0036: ov9732_power_on: VVDN: power on
[ 92.720939] ov9732 2-0036: ov9732_power_on: Power ON success
[ 92.727140] ov9732 2-0036: ov9732_power_off: VVDN: power off
[ 92.959233] ov9732 2-0036: ov9732_power_on: VVDN: power on
[ 92.968891] ov9732 2-0036: ov9732_power_on: Power ON success
[ 92.976796] ov9732 2-0036: ov9732_set_exposure: val: 3038
[ 92.984399] ov9732_set_mode: VVDN: called with set mode value 0
your response will be awaited.
