Overclocking pascal under linux w/o X
Hi there,
I’m using a server for mining and as such it has no X.
Anyone aware of options on overclocking it then? Want +750 on VRAM and -38% on max power. Those settings are extremely stable and it runs mostly on 918mV @61 degrees then.
Forced to use Windows 10 now as I can’t seem to overclock it from cli. nvidia-settings keeps complaining it can’t connect to X, even when using options that only have CLI output. Kinda upsetting especially since it’s also advertised for CUDA/OpenCL.
TIA
Voltage tuning is not available/possible in Linux.
Power limiting is available.
GPU/RAM overclocking/downclocking are available.
Everything can be done using nvidia-settings, e.g.
Overclock RAM by 400MHz:
nvidia-settings -a [gpu:0]/GPUMemoryTransferRateOffset[3]=400
Yeah, it is really annoying that nvidia-settings is hardwired with X11.
If you are familiar with Docker you can run X11 in a container without having to install it on your host. See: https://github.com/BugRoger/dockerfiles/tree/master/nvidia-settings
You need to bake in the proper xorg.conf depending on your rig. Mount in in the nvidia driver and cuda toolkit from the host.
