I am trying to profile a simple Fully-Connected layer in PyTorch using NCU and I see some unexplainable observations.
import torch
import torch.nn as nn
# Define a simple linear model
class SimpleLinearModel(nn.Module):
def __init__(self, input_dim, output_dim):
super(SimpleLinearModel, self).__init__()
self.linear = nn.Linear(input_dim, output_dim)
def forward(self, x):
return self.linear(x)
# Parameters
input_dim = 256
output_dim = 29423
batch_size = 32
device = torch.device('cuda' if torch.cuda.is_available() else 'cpu')
print('[DEBUG]:', device)
input_ = torch.randn(batch_size, input_dim).to(device)
epochs = 20
# Initialize the model
linear_model = SimpleLinearModel(input_dim, output_dim)
linear_model.to(device)
linear_model.eval()
print(sum(p.numel() for p in linear_model.parameters()))
for _ in range(epochs):
pred = linear_model(input_)
In this code our estimation is that the number of floating point operations and number of memory accesses should increase linearly with the batch size of the input data. Where as we are getting the following observation:
BS | Mem Accesses (MB) | FLOPs (G) |
1 | 32.44 | 0.4852 |
8 | 32.46 | 0.4851 |
16 | 32.44 | 0.4852 |
32 | 35.68 | 0.4852 |
64 | 32.45 | 0.4856 |
1024 | 35.60 | 0.4852 |
I am using the following code to compute the memory accesses:
col = "gpu__time_duration.sum"
filtered_df = df[["dram__bytes.sum.per_second [Gbyte/s]", col]]
filtered_df["mem"] = df["dram__bytes.sum.per_second [Gbyte/s]"] * df[col]
mem = np.sum(filtered_df["mem"].values)
print(f"mem: {mem/1000/20} MB") # Divide 20 to get per epoch
I am using the following code to compute the floating point operations:
def _ncu_get_flops_single(kernel_data: dict, col: str, breakdown=None) -> float:
flops = (kernel_data['smsp__sass_thread_inst_executed_op_fadd_pred_on.sum.per_cycle_elapsed [inst/cycle]'] \
+ kernel_data['smsp__sass_thread_inst_executed_op_fmul_pred_on.sum.per_cycle_elapsed [inst/cycle]'] \
+ kernel_data['derived__smsp__sass_thread_inst_executed_op_ffma_pred_on_x2 [inst]']) \
* kernel_data['smsp__cycles_elapsed.avg.per_second [Ghz]'] \
* kernel_data[col]
return flops
def ncu_get_flops(kernel_data: dict, data_width: int, col: str) -> float:
"""return all double/single/half/tensor FLOPs (count of FLoat OP)"""
double = _ncu_get_flops_double(kernel_data, col)
single, fadd, fmul, ffma = _ncu_get_flops_single(kernel_data, col, breakdown=True)
half = _ncu_get_flops_half(kernel_data, col)
tensor, tensor_sum, factor = _ncu_get_flops_tensor(kernel_data, col, breakdown=True)
all_flops = (
_ncu_get_flops_double(kernel_data, col),
_ncu_get_flops_single(kernel_data, col),
_ncu_get_flops_half(kernel_data, col),
_ncu_get_flops_tensor(kernel_data, col)
flops = sum(all_flops)
return flops
all_flops, all_tensors = 0, 0
for i in range(len(df)):
f, tensors = ncu_get_flops(df.iloc[i], 32, col)
all_flops += f
all_tensors += tensors
print('FLOPS:', all_flops/1e6/20) # in GFLOPs
My assumption is that there are some heavy overheads which make the effect of batch sizess negligible. Can somebody explain me why is this happening?
