When using sink0
with overlay size much reduced (like 640x360, to mimic P-in-P like effect), the overlay gets corrupted and I see red pixel band as following.
(the red band actually changes in size as mouse cursor goes over it)
The following, with original config, of course works.
$ cd /opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app
$ deepstream-app -c ./source1_csi_dec_infer_resnet_int8.txt
However when width
and height
of the sink0
is changed to something like 1/9 the size, this isssue starts happening
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=Overlay
type=5
sync=0
display-id=0
offset-x=0
offset-y=0
width=640
height=360
overlay-id=1
source-id=0
When 960
x 540
(1/4 the size) is specified, it works fine.
When 480
x 270
(1/16) is specified, it does not show the overlay at all.
Also, not sure if this is relevant, when the issue occurs, you see “System throttled due to Over-current” warning message on the desktop.
Please let me know if there is a way to circumbent this issue to show the reduced image overlay using DeepStream on Jetson.
I’m testing this on Jetso Xavier NX Developer Kit with JetPack 4.5.1 image, with RaspberryPi Camera Module v2.
