Overlay 问题
请教一下 我想使用JAO里的RGMII接口,使用overlay方式,下述的代码是否有问题?
  • Device Tree Overlay file for the pinctrl_mcp23s08 driver.
  • the driver is being assigned to i2c bus 0.
  • You build this overlay file using te Device Tree Compiler on the machine (dtc)
  • The command used to build the device tree blob is:
  • dtc -@ -I dts -O dtb -o pinctrl_mcp23s08_ol.dtbo pinctrl_mcp23s08_ol.dts
/dts-v1/;
/plugin/;
compatible = “nvidia,p3737-0000+p3701-0000”;
overlay-name = “JAO-RGMII Overlay”;
fragment@0 {
	target-path = "/";
	__overlay__ {
        bus@0 {
                /* EQOS */
                ethernet@2310000 {
                    status = "okay";
                    nvidia,mac-addr-idx = <0>;
                    nvidia,mac-platform-mtu = <8000>;
                    /* 1=enable, 0=disable */
                    nvidia,pause_frames = <0>;
                    nvidia,phy-reset-gpio = <&tegra_main_gpio TEGRA234_MAIN_GPIO(G, 5) 0>;
                    phy-mode = "rgmii-id";
                    phy-handle = <&phy>;
                    /delete-node/ fixed-link;
                    fixed-link {
                    speed = <0x3e8>;
                    full-duplex;
                    mdio {
                    compatible = "nvidia,eqos-mdio";
                    #address-cells = <1>;
                    #size-cells = <0>;
                    phy: phy@0 { /* phy@1 */
                        reg = <0>; /* reg = <1>;设备树的地址要对应上  按照官方的都是偏移1地址,MDIO连接不上,遂都改为0 */
                        nvidia,phy-rst-pdelay-msec = <224>; /* msec */
                        nvidia,phy-rst-duration-usec = <10000>; /* usec */
                        interrupt-parent = <&tegra_main_gpio>;
                        interrupts = <TEGRA234_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
Sorry for the late response.
仍然是问题 请指导一下 非常感谢
See Rgmii的rx-delay和tx-delay如何在设备树改? - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
