Hi!
Is overlayfs supported when the root filesystem is encrypted and located on an external device?
My setup:
Jetson flashed with
ROOTFS_ENC=1 -
L4T 36.4.4
Root filesystem on NVMe
Overlayfs enabled via
sudo nv_overlayfs_config -e -
Status check (after reboot)
sudo nv_overlayfs_config -s -
Output:
Overlayfs is enabled
However, I do not see an overlay mount in mount / findmnt. Filesystem changes remain persistent across reboots, which suggests overlayfs is not actually active
Below is the lsblk output.
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 16M 1 loop
mmcblk0 179:0 0 59.2G 0 disk
├─mmcblk0p1 179:1 0 57.8G 0 part
├─mmcblk0p2 179:2 0 128M 0 part
├─mmcblk0p3 179:3 0 768K 0 part
├─mmcblk0p4 179:4 0 31.6M 0 part
├─mmcblk0p5 179:5 0 128M 0 part
├─mmcblk0p6 179:6 0 768K 0 part
├─mmcblk0p7 179:7 0 31.6M 0 part
├─mmcblk0p8 179:8 0 80M 0 part
├─mmcblk0p9 179:9 0 512K 0 part
├─mmcblk0p10 179:10 0 64M 0 part
├─mmcblk0p11 179:11 0 80M 0 part
├─mmcblk0p12 179:12 0 512K 0 part
├─mmcblk0p13 179:13 0 64M 0 part
├─mmcblk0p14 179:14 0 400M 0 part
└─mmcblk0p15 179:15 0 479.5M 0 part
mmcblk0boot0 179:32 0 4M 1 disk
mmcblk0boot1 179:64 0 4M 1 disk
zram0 252:0 0 3.8G 0 disk [SWAP]
zram1 252:1 0 3.8G 0 disk [SWAP]
zram2 252:2 0 3.8G 0 disk [SWAP]
zram3 252:3 0 3.8G 0 disk [SWAP]
zram4 252:4 0 3.8G 0 disk [SWAP]
zram5 252:5 0 3.8G 0 disk [SWAP]
zram6 252:6 0 3.8G 0 disk [SWAP]
zram7 252:7 0 3.8G 0 disk [SWAP]
nvme0n1 259:0 0 931.5G 0 disk
├─nvme0n1p1 259:1 0 400M 0 part /boot
├─nvme0n1p2 259:2 0 899.6G 0 part
│ └─crypt_root 253:0 0 899.6G 0 crypt /
├─nvme0n1p3 259:3 0 128M 0 part
├─nvme0n1p4 259:4 0 768K 0 part
├─nvme0n1p5 259:5 0 31.6M 0 part
├─nvme0n1p6 259:6 0 128M 0 part
├─nvme0n1p7 259:7 0 768K 0 part
├─nvme0n1p8 259:8 0 31.6M 0 part
├─nvme0n1p9 259:9 0 80M 0 part
├─nvme0n1p10 259:10 0 512K 0 part
├─nvme0n1p11 259:11 0 64M 0 part /boot/efi
├─nvme0n1p12 259:12 0 80M 0 part
├─nvme0n1p13 259:13 0 512K 0 part
├─nvme0n1p14 259:14 0 64M 0 part
├─nvme0n1p15 259:15 0 400M 0 part
│ └─crypt_UDA 253:1 0 384M 0 crypt /mnt/crypt_UDA
└─nvme0n1p16 259:16 0 479.5M 0 part
Any guidance or confirmation would be appreciated.
