Hi there,
I’m writing some container classes for the device side, and I’ve stumbled upon this error. When compiling this code:
//-*-c++-*-
#include "stdlib.h"
#include "stdio.h"
__device__ inline
void *operator new(size_t size) {return malloc(size);}
__device__ __host__ inline
void operator delete(void *p) {free(p);}
__device__ inline
void *operator new[](size_t size) {return malloc(size);}
__device__ inline
void operator delete[](void *p) {free(p);}
__global__ void arraynew()
char* ptr = new char[100];
printf("ptr is %p\n", ptr);
delete[] ptr;
struct Bucket {
//default constructor
__device__ inline Bucket() : key(0), data(0){}
__device__ inline Bucket(int k, int d) : key(k), data(d) {}
int key;
int data;
Bucket* ptr2 = new Bucket[100];
printf("ptr2 is %p\n", ptr2);
delete[] ptr2;
int main()
arraynew<<<1,1>>>();
return(0);
It first looks as if I am able to overload the new operator but then I get:
Centauri-2:test malfunct$ nvcc -arch sm_20 arraynew.cu -keep
./arraynew.cu(32): Error: External calls are not supported (found non-inlined call to __cxa_vec_new2)
Centauri-2:test malfunct$ grep __cxa_vec_new2 *
arraynew.cpp2.i:__cuda_local_var_28154_11_non_const_ptr2 = ((struct _ZZ8arraynewvE6Bucket *)(__cxa_vec_new2(100UL, 8UL, 0UL, _ZZ8arraynewvEN6BucketC1Ev, ((void (*)(void *))0), _Znam, _ZdaPv)));
arraynew.cpp3.i:__cuda_local_var_28154_11_non_const_ptr2 = ((struct _ZZ8arraynewvE6Bucket *)(__cxa_vec_new2(100UL, 8UL, 0UL, _ZZ8arraynewvEN6BucketC1Ev, ((void (*)(void *))0), _Znam, _ZdaPv)));
arraynew.cudafe1.c:extern void *__cxa_vec_new2();
arraynew.cudafe1.gpu:__cuda_local_var_28154_11_non_const_ptr2 = ((struct _ZZ8arraynewvE6Bucket *)(__cxa_vec_new2(100UL, 8UL, 0UL, _ZZ8arraynewvEN6BucketC1Ev, ((void (*)(void *))0), _Znam, _ZdaPv)));
arraynew.cudafe2.c:extern int __cxa_vec_new2();
arraynew.cudafe2.gpu:__cuda_local_var_28154_11_non_const_ptr2 = ((struct _ZZ8arraynewvE6Bucket *)(__cxa_vec_new2(100UL, 8UL, 0UL, _ZZ8arraynewvEN6BucketC1Ev, ((void (*)(void *))0), _Znam, _ZdaPv)));
Is some workaround possible? I suppose that library routine is not yet included in the device compiler, but I don’t think there is any reason it cannot be implemented.
Best,
Eray
