oView Login failure
the locathost login as shown in your tutorial causes the following error.
thx, Matthias
solved it. nucleus needs to be installed
Glad you figured it out. We need to make this more obvious.
Brian
Same problem here I think. Where can I find / install nucleus?
You install it from the Collaboration tab in the Launcher.
@Brian - Thanks I can sign in now, but still not transfer a model from SketchUp to Omniverse View. I create a new topic.
