[ovrtx 0.4.0] OmniLidar returns 0 points when numberOfEmitters is authored — is the explicit emitter table supported?
I am evaluating `ovrtx` as a Kit-free RTX lidar harness and hit a wall importing an existing vendor lidar profile. I have reduced it to a two-line change against your own shipped example, so I hope this is easy to check.
**Summary**
Adding two `omni:sensor:Core:` attributes to the `OmniLidar` prim in `examples/python/lidar/lidar_example.usda` drops the returned point count from 275,027 to 0. Either of the following is independently sufficient:
- `numberOfEmitters` + `numberOfChannels`
- `emitterState:s001:azimuthDeg` + `emitterState:s001:elevationDeg`
The more telling detail: it is not that rays are cast and the returns are then rejected. The `PointCloud` tensor allocation itself collapses from 921,600 to 1.
scene Counts[0] valid(0x40) Flags alloc
stock example 275027 275027 921600
+ numberOfEmitters=64, numberOfChannels=64 0 0 1
+ 8-entry azimuthDeg / elevationDeg 0 0 1
That reads to me as the sensor model computing Nmax as 0 from the emitter table rather than scaling the output buffer to it. No error or warning is emitted at `log_level=“info”`, and the sensor is otherwise recognised and scheduled normally:
[Info] [omni.sensorscheduling] Added sensor … with tick rate 10.00 Hz, exposure time 0.100000 s
[Info] [omni.rtx.sensors] Sensor Type is eOmniLidar
[Info] [omni.rtx.sensors] LIDAR: AuxiliaryOutputType: 0, Enabled compaction: 1
The failing log is structurally identical to the working one.
**Reproduction**
All files are in the attached `ovrtx_lidar_repro.zip` (self-contained, no external assets).
pip install ovrtx ovstage numpy
python run_repro.py --all
scene valid points
scene_A_stock 275027
scene_B_emitter_counts 0
scene_C_emitter_arrays 0
Scene B in full. This is the only difference from your shipped example:
def OmniLidar “Lidar” (
prepend apiSchemas = \["OmniSensorGenericLidarCoreAPI"\]
token omni:sensor:Core:elementsCoordsType = "CARTESIAN"
uint omni:sensor:Core:numberOfEmitters = 64      # <-- added
uint omni:sensor:Core:numberOfChannels = 64      # <-- added
double2 omni:sensor:frameRate = (10, 1)
double3 xformOp:translate = (0, 0, 1)
float3 xformOp:rotateXYZ = (90, 0, -90)
uniform token\[\] xformOpOrder = \["xformOp:translate", "xformOp:rotateXYZ"\]
`diagnose_sceneB.py` in the archive reproduces the allocation table above.
**What I already ruled out**
Applied on top of scene B, none of these restore the allocation. All stay at `alloc=1`, `Counts=0`:
- `includeInvalidPoints = 1`, so this is not a case of returns being generated and then dropped as invalid
- `instantLidar = 1`
- `partialOutputs = 0`
- `numRows` / `numCols`, individually and together
- `rotPatternFiringResDeg = 0.1`
- `numLines = 64` together with `numRaysPerLine = [3600]`
- explicitly applying `OmniSensorGenericLidarCoreEmitterStateAPI:s001`. It is already auto-applied: `OmniSensorGenericLidarCoreAPI` lists it in its own `apiSchemas` at `generatedSchema.usda` line 403.
Tested independently on top of a working default-config lidar, the following are harmless and still return points. This is what narrows the cause to the emitter counts and the azimuth/elevation arrays specifically:
- `emitterStatesFile = “”`
- `stateResolutionStep = 1`
- the empty emitter arrays: `bank`, `distanceCorrectionM`, `focalDistM`, `focalSlope`, `horOffsetM`, `reportRateDiv`, `roi`, `vertOffsetM`
Also ruled out as a cause: missing non-visual material labels. Per `docs/sensors/nonvisual_materials.rst`, unlabeled surfaces fall back to `DefaultMaterial`, and empirically a default-config lidar does return points in the very same scene.
**Why I suspect a gap rather than my own mistake**
A recursive grep over the whole `ovrtx` repository returns zero matches for `emitterState`, `numberOfEmitters`, `numberOfChannels`, and `EmitterStateAPI`. No example, doc page, docs-test, or skill exercises the explicit emitter-table path. Both shipped lidar examples set exactly one `omni:sensor:Core:` attribute and rely on defaults for everything else.
The published docs I checked, namely `sensors/lidar.html`, `sensors/pointclouds.html`, `sensors/nonvisual_materials.html` and `sensors/configuration.html`, document the output attributes and channels thoroughly but say nothing about emitter tables.
The only mention anywhere is a single sentence in `skills/configuring-lidar-sensors/SKILL.md`: “Add emitter-state API schemas only when authoring custom firing patterns with explicit emitter state arrays.” There is no worked example of what a complete explicit emitter table requires.
**Questions**
1. Is the explicit emitter-table path, meaning `numberOfEmitters` plus per-channel `emitterState:sNNN:*` arrays, supported in ovrtx 0.4.0? Or is it schema surface that is not yet wired to the sensor model?
2. If it is supported, which additional attributes must accompany `numberOfEmitters` so the model can size the `PointCloud` output? A minimal working USDA would resolve this completely.
3. Is there a supported path to import an Isaac Sim RTX lidar profile, in the `omni:sensor:Core:*` form such as a 64-channel Hesai or Livox calibration table, into ovrtx? That is my actual goal: reproducing an existing sensor’s real firing geometry outside Kit.
Happy to test patches or provide more logs.
**Environment**
ovrtx 0.4.0.346409 (PyPI)
ovstage 0.1.0.346039 (PyPI)
Python 3.10.12
OS Ubuntu, Linux 6.8.0-124-generic
GPU 2x NVIDIA GeForce RTX 3090 Ti
Driver 580.159.04
numpy 2.2.6
Note: the README states Python 3.11+, but the wheel is `py3-none` and installs and runs correctly on 3.10.12.
