I have a HP Proliant DL 380 Gen10 server with Server 2016 Hyper-V with one VM one it, a Remote Desktop Session Host.
I installed a Quadro P4000 in the physical host, and assigned it to the VM with DDA
The card is available in the VM, and i used the drivers from HP version 384.94
I changed the computer policy "use standard graphical adapter…"
When I play a YouTube video and i run the NvGpuUtilization utility I see some GPU use, about 10 to 15 %, but I also see CPU use go up.
And the video is not smooth, its choppy.
How can I solve this problem?
I run nvidia-smi.exe and the output is this:
==============NVSMI LOG==============
Timestamp : Wed Jul 18 13:59:16 2018
Driver Version : 384.94
Attached GPUs : 1
GPU 00003616:00:00.0
Product Name : Quadro P4000
Product Brand : Quadro
Display Mode : Disabled
Display Active : Disabled
Persistence Mode : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 1920
Driver Model
Current : WDDM
Pending : WDDM
Serial Number : 0324617055398
GPU UUID : GPU-1e97340f-296c-ac05-4f01-e00aca63849c
Minor Number : N/A
VBIOS Version : 86.04.56.00.0B
MultiGPU Board : No
Board ID : 0x36160000
GPU Part Number : 900-5G410-0355-000
Inforom Version
Image Version : G410.0501.00.03
OEM Object : 1.1
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization mode : Pass-Through
PCI
Bus : 0x00
Device : 0x00
Domain : 0x3616
Device Id : 0x1BB110DE
Bus Id : 00003616:00:00.0
Sub System Id : 0x11A310DE
GPU Link Info
PCIe Generation
Max : 3
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : 0
Tx Throughput : 0 KB/s
Rx Throughput : 2000 KB/s
Fan Speed : 46 %
Performance State : P8
Clocks Throttle Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
Sync Boost : Not Active
FB Memory Usage
Total : 8192 MiB
Used : 258 MiB
Free : 7934 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 229 MiB
Free : 27 MiB
Compute Mode : Default
Utilization
Gpu : 11 %
Memory : 1 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Texture Shared : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending : N/A
Temperature
GPU Current Temp : 30 C
GPU Shutdown Temp : 96 C
GPU Slowdown Temp : 93 C
Memory Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 5.98 W
Power Limit : 105.00 W
Default Power Limit : 105.00 W
Enforced Power Limit : 105.00 W
Min Power Limit : 60.00 W
Max Power Limit : 105.00 W
Clocks
Graphics : 139 MHz
SM : 139 MHz
Memory : 405 MHz
Video : 544 MHz
Applications Clocks
Graphics : 1202 MHz
Memory : 3802 MHz
Default Applications Clocks
Graphics : 1202 MHz
Memory : 3802 MHz
Max Clocks
Graphics : 1708 MHz
SM : 1708 MHz
Memory : 3802 MHz
Video : 1544 MHz
Max Customer Boost Clocks
Graphics : 1708 MHz
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes
Process ID : 1108
Type : C+G
Name : Insufficient Permissions
Used GPU Memory : Not available in WDDM driver model
Process ID : 1412
Type : C+G
Process ID : 4828
Type : C+G
Process ID : 7528
Type : C+G
Process ID : 8448
Type : C+G
Process ID : 8584
Type : C+G
Process ID : 10980
Type : C+G
Name : C:\Program Files (x86)\Internet Explorer\iexplore.exe
