agx@agx-1:~ » sudo apt install ffmpeg
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
ffmpeg
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
3 not fully installed or removed.
Need to get 0 B/14.3 MB of archives.
After this operation, 52.4 MB of additional disk space will be used.
debconf: delaying package configuration, since apt-utils is not installed
(Reading database ... 236222 files and directories currently installed.)
Preparing to unpack .../ffmpeg_7%3a4.2.7-nvidia_arm64.deb ...
Unpacking ffmpeg (7:4.2.7-nvidia) ...
Replacing files in old package libavcodec-dev:arm64 (7:4.2.7-0ubuntu0.1) ...
Replacing files in old package libavdevice-dev:arm64 (7:4.2.7-0ubuntu0.1) ...
Replacing files in old package libavfilter-dev:arm64 (7:4.2.7-0ubuntu0.1) ...
Replacing files in old package libavformat-dev:arm64 (7:4.2.7-0ubuntu0.1) ...
Replacing files in old package libavutil-dev:arm64 (7:4.2.7-0ubuntu0.1) ...
dpkg: error processing archive /var/cache/apt/archives/ffmpeg_7%3a4.2.7-nvidia_arm64.deb (--unpack):
trying to overwrite '/usr/include/aarch64-linux-gnu/libpostproc/postprocess.h', which is also in package libpostproc-dev:arm64 7:4.2.7-0ubuntu0.1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
