Yes it is possible
When I flashed xavier before, the network cable was not connected. Could this be the cause of my problem, so when I flash xavier, do I need to connect the network cable to xavier?
The display is responsive, indicating that there is no problem with the connection, but only a progress bar of auto flashes on the display, followed by the NVIDIA interface, and then the display screen is black and there is no follow-up
If you only want to flash board, then no needed.
Yes, sounds caused by adapters.
I just asked you a question. A new account can only comment three times under a question, so I change my account to express my gratitude for your help. Yes, I just want to flash board. I try to change the monitor. Thank you very much for your reply.
After changing the HDMI direct connected monitor, my problem has been solved. Thank you again.
