Hi, @jiwook720 , have you tried updating the packages from the Isaac ROS NITROS repository (which include isaac_ros_gxf) and the Isaac ROS Common repository? Deleting the “build”, “log” and “install” directories in your ROS workspace to build again clean. The error indicates that some cmake prefix files newly introduced in DP3 have not been setup in this build.
Related topics
| Can't Install GFX Tensor RT: "Could not find TENSORRT" | 2 | 52 | July 10, 2025 | |
| Failure in isaac_ros_gxf during build of isaac_ros_nitros | 1 | 35 | April 25, 2025 | |
| Cmake could not find isaac_ros_image_proc config files | 2 | 627 | November 24, 2023 | |
| Failure in isaac_ros_gxf during build of isaac_ros_nitros | 5 | 96 | May 28, 2025 | |
| Unable to locate any Isaac ROS package | 9 | 224 | May 28, 2025 | |
| Issac ROS - Nova Carter Error Building From Source | 3 | 208 | August 8, 2024 | |
| Could NOT find ROS package isaac_tutorials | 3 | 712 | July 24, 2023 | |
| ISAAC ROS from source | 2 | 566 | February 9, 2024 | |
| Missing tensorrt package in isaac_ros_common | 2 | 527 | July 11, 2023 | |
| Can not build 'nvblox ros 'issac ros nvblox | 3 | 193 | March 3, 2025 |
