Hello
I have a connextX5 mellanox adapter on a windows10 machine
Its conected to a another custom hardware at 100GBE
I want to test the max thougthut of this link/setup
which is the best tool we can find that generate packets at max thoughput using this setup ?
Shal
Hi
You can use iperf for windows .
You can also use NTTCP
thank you very much
I will try and return a feedback
Iperf3 and ntttcp use tcp for passing some control data , not the test data
Is there any tool that use only udp connection , without any tcp connection ?
Sha
iperf and iperf3 can both be used in UDP mode with the -u flag, but it sounds like you may be looking for a tool capable of stateless traffic generation. Ostinato is a stateless traffic generator inspired by IXIA.
https://ostinato.org/
