Description
I’m using the trtexec to parsing the onnx model and got the error as title. What’s the ‘rank’ mean and how could I fixed this error?
The trtexec command I used is:
trtexec.exe --onnx=C:\Users\jackg\Downloads\project\model\Depth\test_modified.onnx --saveEngine=C:\Users\jackg\Downloads\project\model\Depth\engine\test_fp16.trt --minShapes=‘input’:1x6x480x640 --optShapes=‘input’:1x6x480x640 --maxShapes=‘input’:1x6x480x640 --verbose --shapes=‘input’:1x6x480x640 --fp16
Here is the error image.
Environment
TensorRT Version : 8.4.1.5
NVIDIA GPU : 3080
NVIDIA Driver Version : 516.40
CUDA Version : 11.1
CUDNN Version : 8
Operating System : windows 10
Python Version (if applicable) :
Tensorflow Version (if applicable) :
PyTorch Version (if applicable) :
Baremetal or Container (if so, version) :
Relevant Files
Here is the onnx model. I convert it from tensorflow by using tf2onnx.
test_modified.zip (5.8 MB)
Steps To Reproduce
NVES
June 23, 2022, 7:07am
#2
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
Hi @NVES ,
I’ve “already” share the ONNX model and trtexec command. Have you seen my post clearly?
Looks like you already created a Git issue, please refer to the response in the git issue.
opened 06:52AM - 23 Jun 22 UTC
triaged
## Description
I'm using the trtexec to parsing the onnx model and got the er… ror as title. What's the 'rank' mean and how could I fixed this error?
> trtexec.exe --onnx=C:\Users\jackg\Downloads\project\model\Depth\test_modified.onnx --saveEngine=C:\Users\jackg\Downloads\project\model\Depth\engine\test_fp16.trt --minShapes='input':1x6x480x640 --optShapes='input':1x6x480x640 --maxShapes='input':1x6x480x640 --verbose --shapes='input':1x6x480x640 --fp16
<img width="946" alt="image" src="https://user-images.githubusercontent.com/17614632/175234184-3cf759c9-d271-4a14-bc30-d8cacfa5a1ae.png">
## Environment
**TensorRT Version**: 8.4.1.5
**NVIDIA GPU**: 3080
**NVIDIA Driver Version**: 516.40
**CUDA Version**: 11.1
**CUDNN Version**: 8
**Operating System**: windows 10
**Python Version (if applicable)**:
**Tensorflow Version (if applicable)**:
**PyTorch Version (if applicable)**:
**Baremetal or Container (if so, version)**:
## Relevant Files
[test_modified.zip](https://github.com/NVIDIA/TensorRT/files/8964731/test_modified.zip)
## Steps To Reproduce
Thank you.
