Almost every time I wake my computer from sleep, the screens remain black. The system is on and alive, but there is nothing being displayed. The only “fix” is to press down on my PC’s power button and force it to shutdown. Unplugging monitors and plugging them back in does not work. This has happened across multiple driver versions.
The error I see in when running journalctl -b -1 is: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
I’ve attached the output of sudo dmesg and journalctl --user-unit plamsa-kwin_wayland --boot 0.
GPU: RTX 4070 Ti SUPER Driver Version: 580.119.02 OS: Fedora 43 Kernel: 6.18.12-200.fc43.x86_64
I have the same issue. Screen remains black after waking up the computer from sleep. Changing TTY helps to fix this issue. Tried proprietary and open driver versions from RPMFusion repository.
Hello, I’m on driver 595.45.04 with the latest version of Bazzite, and I’m getting this issue as well. I was able to get into the system by typing my password on a blank screen upon waking up and then using Ctrl+Alt+F3 to switch to a text based terminal and back, which works to reset screen detection. Attached are all the relevant logs
I ran 50 cycles of suspend/resume operation via systemctl suspend and GUI option while runnig youtube videos on firefox browser but did not observe reported “pageflip timed out error” after resume operation.
Setup -
Host: OMEN by HP 40L Gaming Desktop GT21-1xxx
OS: CachyOS x86_64
Kernel: Linux 6.19.10-1-cachyos
NVIDIA GeForce RTX 3070
Driver 595.58.03
Wayland
KDE Plasma 6.6.3
Display 1 - AOC AG276QZD connected via DP with 2560 x 1440 resolution and refresh rate as 144 Hz
Display 2 - MSI G274F connected via HDMI with 1920 x 1089 resolution and refresh rate as 180 Hz
Could you please share below information.
Repro frequency
How long you keep system in sleep mode.
Are you using s2idle or deep mode.
What applications are running on system when it enters sleep mode.
I usually see this every other time I try to wake my PC from sleep.
Length of sleep mode time varies. Sometimes it’s an hour or two, other times it’s 14-16 hours, or more. I haven’t noticed a relationship between sleep time and this bug occurring.
A mix. I’m not the most tech-savvy, but I see both s2idle and deep when I look for suspend in journalctl (i.e. sudo journalctl | grep "PM: suspend" | tail -20). It looks like it alternates between deep and s2idle. To the untrained eye, it doesn’t look like there’s a correlation between one sleep mode or the other and the crash; the crash seems like it happens regardless of mode.
Discord, Firefox, Steam, Konsole, and Dolphin (file explorer app) are the main ones that stay open when I put the computer to sleep.
