I have been having intermittent issues on nvidia-open drivers 615.71.09-1 with a 4070 Ti Super on Cachy KDE Wayland. What is happening seems to change per boot, with some results more common than others. Rolling back to 610.57.04-1 drivers makes all problems disappear.
I have two monitors connected to my machine, both using DisplayPort. One is an AOC 24G2W1G4, the other is an AOC 24G4ZR.
There are 3 main different outcomes I am seeing after boot:
- The majority of the time when I boot the 24G2W1G4 will be working as normal, but the 24G4ZR will have no image. The monitor’s LED will go white as if it is receiving a signal, but there is no picture. I am also able to see the monitor in my Display Configuration like nothing is wrong:
Sometimes both monitors will work perfectly fine from boot as if nothing is wrong
Rarely my machine will freeze up just before the login screen or shortly after logging in. If it is before the login screen, all I see is a backlight and a frozen mouse.
I have attached a zip containing logs of each different scenario.
I believe these are the relevant logs to help get an idea of what’s going on. This is from the logs where my machine froze up before the login screen:
Sep 25 15:17:13 <hostname-redacted> kwin_wayland[789]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Sep 25 15:17:13 <hostname-redacted> kwin_wayland[789]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Sep 25 15:17:13 <hostname-redacted> kwin_wayland[789]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Sep 25 15:17:04 cachyos-x8664 kernel: nvidia-modeset: WARNING: GPU:0: Lost display notification (0:0x00000000); continuing.
Sep 25 15:17:12 cachyos-x8664 kernel: NVRM: GPU at PCI:0000:26:00: GPU-2506dfa4-450e-1186-ac87-c6aa7ec70d19
Sep 25 15:17:12 cachyos-x8664 kernel: NVRM: Xid (PCI:0000:26:00): 16, Head 00000003 Count 00000027
Sep 25 15:17:12 cachyos-x8664 kernel: NVRM: krcWatchdogCallbackVblankRecovery_IMPL: NVRM-RC: RM has detected that 7 Seconds without a Vblank Counter Update on head:D0
Sep 25 15:17:21 cachyos-x8664 kernel: NVRM: Xid (PCI:0000:26:00): 16, Head 00000003 Count 00000028
Sep 25 15:17:21 cachyos-x8664 kernel: NVRM: krcWatchdogCallbackVblankRecovery_IMPL: NVRM-RC: RM has detected that 7 Seconds without a Vblank Counter Update on head:D0
Sep 25 15:17:28 cachyos-x8664 kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00002600] Failed to apply atomic modeset. Error code: -22
Sep 25 15:17:29 cachyos-x8664 kernel: NVRM: Xid (PCI:0000:26:00): 16, Head 00000003 Count 00000029
Sep 25 15:17:29 cachyos-x8664 kernel: NVRM: krcWatchdogCallbackVblankRecovery_IMPL: NVRM-RC: RM has detected that 7 Seconds without a Vblank Counter Update on head:D0
Sep 25 15:17:31 cachyos-x8664 kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00002600] Flip event timeout on head 0
Please let me know if i’ve missed anything.
Logs.zip (1.8 MB)
