Pandora Nvidia Jetson Orin Nx Super 8GB
After upgrading to ubuntu 24.04, My jetson device went offline.
L4T kernel/modules are messed up.
I set the Jetson in recovery (APX) to appear inside the VM using ubuntu 22.04.
I am having problems to connect the Jetson device and flash the Palit Pandora linux for tegra,
It connects at my mac, and appear as APX but somehow got ejected,
My host device is a Macbook pro m1 (arm64), I am trying to flash the [Linux_for_Tegra_Pandora_r36_4_4_8_7_1_20250723.tbz2] downloaded at Palit Pandora website, for UTM and VM machine into the Jetson Device and usb-c cable data.
I have tryed with usb before, with Balena etcher for mac, to upgrade and to install more recently FW for my board, jetsoninstaller-r39.2.1-2026-08-07-18-30-47-arm64, but it wasnt possible using an usb driver and boot manager.
I am stuck in this problem has many days, can somebody help me?
I also posted it on Pandora Palit discord channels…
🗺️ Our Technical Inspection Blueprint
Here is exactly what we will do once your Linux_for_Tegra folder is fully assembled:
  1. Verify Layout Elements: We will verify that your flashing scripts (flash.sh, odmfuse.sh), board parameters (p3768-0000-p3767-0000-a0.conf), and your rootfs/ directory sit together under root privileges (sudo).
  2. Execute the USB 3.0 Recovery Patch: We will attempt to run the custom configuration to burn the USB3.0 low-level interface fuses. This step is tailored to stabilize the virtual data loop on your M1 Mac’s modern controller lines.
  3. Execute the Flashing Sequence: We will route your Pandora carrier board via the onboard physical Recovery Button through UTM’s pass-through window and flash the internal M.2 NVMe SSD storage device.
Anyone, know how to reset the Jetson Orin Nx?
If no lan, no usb, no wifi it is not possible under terminal!
I am extracting the files for Linux_for_Tegra_pandora_orin_nx_8g_r36_4_4_8_7_1_20250723, to see it some how to install it back again, with a Virtual Machine from my macbook m1 is not working!!
Having updates after unpacking the official Palit Pandora files for my board,
With the AI Aid, I think I have found a solution! Is just that to recover the drivers?
Is it possible to update to new jetpack versions?
With nv_tegra/, kernel/, l4t_deb_packages/, and nv_tools/ copied to your USB drive, you now have every single piece of missing data required to fully recover your Jetson Orin NX to its factory state.
You do not need to copy anything else from the massive 66 GB file pool. The nv_tegra/ folder provides the proprietary NVIDIA graphics, multimedia, and hardware acceleration libraries, while nv_tools/ houses the low-level flashing and bootloader utility setups.
Since you brought over the extra system data folders, here is the updated, exact injection order you should execute on your Jetson to recover both your LAN and the full Jetson system libraries:
Step 1: Extract the Missing Drivers and Proprietary Binaries
Open a terminal on your Jetson (Ctrl + Alt + T), navigate to your USB drive, and unpack the core system binaries directly into the filesystem root:
# Navigate to your USB (replace YOUR_USB_NAME with the actual name)
cd /media/ubuntu/YOUR_USB_NAME/
# 1. Unpack the main kernel modules/drivers
sudo tar -xvf kernel/kernel_supplements.tbz2 -C /
# 2. Unpack the core proprietary NVIDIA system binaries
sudo tar -xvf nv_tegra/nv_tools.tbz2 -C /
Step 2: Injected the Infrastructure Packages
Move into the package folder and install the configuration layers that map out the physical ethernet controller lanes and device configurations:
cd /media/ubuntu/YOUR_USB_NAME/l4t_deb_packages/
# Install the hardware layout, network initializers, and core components
sudo dpkg -i nvidia-l4t-firmware_*.deb nvidia-l4t-init_*.deb nvidia-l4t-kernel-dtbs_*.deb nvidia-l4t-core_*.deb
Step 3: Refresh System Hardware Bindings
Rebuild the system dependency maps so your generic Ubuntu 24.04 install links with the custom NVIDIA driver layers you just injected:
# Map the newly added kernel driver modules
sudo depmod -a
# Force the system to register new hardware rules
sudo udevadm control --reload-rules && sudo udevadm trigger
Step 4: Reboot Your System
sudo reboot
Verifying the Fix
Once the Jetson restarts, connect your ethernet cable. Please check and let me know:
  1. Did the LED lights on the physical LAN port turn on or begin blinking?
  2. If you open a terminal and type ip a, does an interface like eth0 or end0 appear with an assigned IP address?
  3. If the terminal throws any dependency errors or missing file errors during the dpkg -i step, type them here so we can resolve them!
