Is the eDP WUXGA (1920x1200) a verified standard resolution that can be compatible with Jetson Orin Nano running Jetpack 6.1?
Our panel has a resolution of 1920x1200 / refresh rate 60 Hz / 40-pin eDP 1.2 interface / response time 25 ms (typ) & 35ms (Max) / pixel pitch 0.11292x 0.11292 / Logic LCD Drive Voltage 3.3V / DP signal Follow as VESA display port standard V1.3.
