I’m using python as a programming language ! with nvidia deepstream 6.1.1with DGPU,
Using same kind of parallel pipeline as using in c++,
uri-decode-bin—>mainstreammux----->streamdemux------>pgie model wise streammux------------>tracker—>sgie---->metamux----> sink
So My concern is I want to re-connect my down camera ----->
what I’m doing now is I make a function I able to know which camera get down that particular camera I removed for the pipeline and checking if the camera is up then I’m creating uri-decode-bin for that particular camera and and linking that into mainstreammux sink pad ------------------>
When I’m doing it It’s working for once after that whole thing are running but that function is not calling again !
Perhaps some of your plugin’s status have not been processed correctly. Could you refer to our source code:sources\apps\apps-common\src\deepstream_source_bin.c first.
