shong
#1
Hello everyone,
I am the beginner of CUDA. I am looking for the sort algorithm. there are two in CUDA samples which I found.
bitonic: the number must power of 2, and the thread is equal number, some one ask for multi-block algorithm, but nobody answer;
radix sort: can use to arbitrary number, but the sample only use to integer, could it use to float.
could you please tell me the efficient sort method to use in parallel? I am very appreciate it if you give some example code.
I am also want know the efficient way to get the maximum and minimum in a large array.
Thanks for you attention!
You can use a radix sort to sort floating point numbers by rearranging the bits as described here:
http://www.stereopsis.com/radix.html
There should be an example of this in the next release of the SDK.
shong
#3
Thank you!
by the way, do you know any quick method to find the maximum and minimum value in arbitrary unmber?
finding the minimum and maximum in a dataset is a classical example of a parallel reduction. Best to modify the reduction
SDK sample to suit your needs.
