Hello, to setup local debugging, step 7 states that I must “D3D acceleration for WPF (applies to local debugging only).” What exactly is this feature for?
Is it true that if you disable this feature then any current-generation games that you play on the same computer will be unable to use it (thus you have to restart computer after re-enabling it) or is unrelated?
If so that seems like quite a hassle.
Thanks for the help.
