Hi All,
I need to remove all 0 in a string.
For example: I have a string like " a b 0 c 0 0 0 a b", i need to output " a b c a b", do you have any suggestions?
Thanks a lot.
Hi All,
Thanks a lot.
Actually the original question is to merge duplicate string: say I have a string like " a b a a a c c a", i need to merge continuous chars to output " a b a 3 c 2 a", any ideas?
My idea is let each thread merge 3 bytes and replace duplicate char with 0, then the string will bed converted to “a b a 3 0 c 2 a”.
We can demonstrate this with a better example, my process is as below:
" a b a a a a a c c c a a",
a b a 2 a 2 a c c 2 a 2
a b a 4 a 1 0 c 3 0 a 2
a b a 5 0 0 0 c 3 0 a 2
Then the problem is how to remove 0, any good idea?
This is outside my area of expertise, but I wonder whether the following paper might be of help:
Markus Billeter, Ola Olsson, and Ulf Assarsson
Efficient Stream Compaction on Wide SIMD Many-Core Architectures
Proceedings of the Conference on High Performance Graphics 2009, New Orleans, LA, 2009, pp. 159-166
http://www.cse.chalmers.se/~billeter/pub/pp/paper.pdf
More generally, the problem at hand appears to be a special case of parallel scan, you might want to search Google Scholar or CiteSeer for that.
Thank you so much :)
