thomas@MyVostro:~/matrixMul/NVIDIA_CUDA_SDK$ make
make[1]: entrant dans le répertoire « /home/thomas/matrixMul/NVIDIA_CUDA_SDK/common »
a - obj/release/bank_checker.cpp_o
a - obj/release/cmd_arg_reader.cpp_o
a - obj/release/cutil.cpp_o
a - obj/release/stopwatch.cpp_o
a - obj/release/stopwatch_linux.cpp_o
a - obj/release/multithreading.cpp_o
make[1]: quittant le répertoire « /home/thomas/matrixMul/NVIDIA_CUDA_SDK/common »
make[1]: Makefile_paramgl: Aucun fichier ou répertoire de ce type // no file or directory
make[1]: *** Pas de règle pour fabriquer la cible « Makefile_paramgl ». Arrêt.
make: *** [lib/libparamgl.so] Erreur 2
Well, I think the problem is that you downloaded a single example rather than install the entire SDK. I have noticed this problem myself. The inidividual samples don’t have the paramgl makefile.
looks like the forum won’t let me attach the makefile to this thread. Just create a text file called Makefile_paramgl in the “common” directory and add the following text (please note that you should add in the NVIDIA notice to the top of the file (excluded here for size sake)).
