I am trying the ParaView Omniverse connector to generate scene that use the volume rendering. Each time when I try to switch to the volume representation, my ParaView crash and close automatically. Everything works normally if I am not using the Omniverse connector view. I just make a test using the wavelet example and below is the error message shown when my ParaView crash.
> Coding Error: in _SetValueImpl at line 6043 of /buildAgent/work/ca6c508eae419cf8/USD/pxr/usd/usd/stage.cpp -- Type mismatch for </Root/Lights/defaultLight.xformOp:translate>: expected 'GfVec3d', got 'GfVec3f'
> Coding Error: in _SetValueImpl at line 6043 of /buildAgent/work/ca6c508eae419cf8/USD/pxr/usd/usd/stage.cpp -- Type mismatch for </Root/Lights/defaultLight.shaping:cone:angle>: expected 'float', got 'double'
> Runtime Error: in Open at line 867 of /buildAgent/work/ca6c508eae419cf8/USD/pxr/usd/usd/stage.cpp -- Failed to open layer @omniverse://localhost:33480/Users/a6000/paraview/Session_13/geometries/Wavelet1_Volume_0_VolumeGeom_.0.000000.usd@
> Runtime Error: in Open at line 867 of /buildAgent/work/ca6c508eae419cf8/USD/pxr/usd/usd/stage.cpp -- Failed to open layer @omniverse://localhost:33480/Users/a6000/paraview/Session_13/topologies/Wavelet1_Volume_0_VolumeGeom_Topology.usd@
> Loguru caught a signal: SIGSEGV
> Stack trace:
> 51 0x407b2a /home/install_code/ParaView-5.9.1-MPI-Linux-Python3.8-64bit/bin/paraview-real() [0x407b2a]
> 50 0x7fcdc64f6083 __libc_start_main + 243
> 49 0x40778a /home/install_code/ParaView-5.9.1-MPI-Linux-Python3.8-64bit/bin/paraview-real() [0x40778a]
> 48 0x7fcdc398e120 QCoreApplication::exec() + 128
> 47 0x7fcdc398562a QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 298
> 46 0x7fcd90398dfe /home/install_code/ParaView-5.9.1-MPI-Linux-Python3.8-64bit/plugins/platforms/../../lib/libQt5XcbQpa.so.5(+0x5edfe) [0x7fcd90398dfe]
> 45 0x7fcdc39de522 QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 1138
> 44 0x7fcdc39e0279 QTimerInfoList::activateTimers() + 985
> 43 0x7fcdc3986dd8 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 280
> 42 0x7fcdc5948260 QApplication::notify(QObject*, QEvent*) + 704
> 41 0x7fcdc594118c QApplicationPrivate::notify_helper(QObject*, QEvent*) + 156
> 40 0x7fcdc39b5ccb QObject::event(QEvent*) + 123
> 39 0x7fcdc39c1c58 QTimer::timerEvent(QTimerEvent*) + 40
> 38 0x7fcdc39c1927 QTimer::timeout(QTimer::QPrivateSignal) + 39
> 37 0x7fcdc39b51ea QMetaObject::activate(QObject*, int, int, void**) + 1850
> 36 0x7fcdc4a82ec5 /home/install_code/ParaView-5.9.1-MPI-Linux-Python3.8-64bit/bin/../lib/libpqCore-pv5.9.so.1(+0x7bec5) [0x7fcdc4a82ec5]
> 35 0x7fcdc4b54601 pqView::forceRender() + 97
> 34 0x7fcdb9a55813 vtkSMViewProxy::StillRender() + 307
> 33 0x7fcdc2c572e5 vtkPVSessionBase::ExecuteStream(unsigned int, vtkClientServerStream const&, bool) + 53
> 32 0x7fcdc2c582bb vtkPVSessionCore::ExecuteStream(unsigned int, vtkClientServerStream const&, bool) + 59
> 31 0x7fcdc2c58482 vtkPVSessionCore::ExecuteStreamInternal(vtkClientServerStream const&, bool) + 242
> 30 0x7fcdc1b09ddd vtkClientServerInterpreter::ProcessStream(vtkClientServerStream const&) + 29
> 29 0x7fcdc1b09b3e vtkClientServerInterpreter::ProcessOneMessage(vtkClientServerStream const&, int) + 1294
> 28 0x7fcdc1b0940d vtkClientServerInterpreter::ProcessCommandInvoke(vtkClientServerStream const&, int) + 1229
> 27 0x7fcdc1b08da9 vtkClientServerInterpreter::CallCommandFunction(char const*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&) + 345
> 26 0x7fcd40dda944 vtkPVOmniConnectRenderViewCommand(vtkClientServerInterpreter*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&, void*) + 3764
> 25 0x7fcdc1b08da9 vtkClientServerInterpreter::CallCommandFunction(char const*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&) + 345
> 24 0x7fcdba80bbc8 vtkPVRenderViewCommand(vtkClientServerInterpreter*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&, void*) + 8312
> 23 0x7fcdb99b3ce1 vtkPVRenderView::StillRender() + 97
> 22 0x7fcd40bbbe2a vtkPVOmniConnectRenderView::Render(bool, bool) + 650
> 21 0x7fcdb99bfb3a vtkPVRenderView::Render(bool, bool) + 2010
> 20 0x7fcdc0b2cd72 vtkGenericOpenGLRenderWindow::Render() + 194
> 19 0x7fcdc0bbc4e1 vtkOpenGLRenderWindow::Render() + 81
> 18 0x7fcdc0131d8b vtkRenderWindow::Render() + 267
> 17 0x7fcdc01313f5 vtkRenderWindow::DoStereoRender() + 213
> 16 0x7fcdc014361f vtkRendererCollection::Render() + 191
> 15 0x7fcdc013d515 vtkRenderer::Render() + 2533
> 14 0x7fcdc0bc2c7f vtkOpenGLRenderer::DeviceRender() + 143
> 13 0x7fcdc0b03e4f vtkCameraPass::Render(vtkRenderState const*) + 527
> 12 0x7fcdb59ad66f vtkViewNode::Traverse(int) + 127
> 11 0x7fcdb59ad66f vtkViewNode::Traverse(int) + 127
> 10 0x7fcdb59ad6e6 vtkViewNode::Traverse(int) + 246
> 9 0x7fcd409981a8 vtkOmniConnectVolumeMapperNode::Render(bool) + 536
> 8 0x7fcd40997c36 vtkOmniConnectVolumeMapperNode::RenderVolume(vtkOmniConnectActorNodeBase*, vtkVolume*, vtkVolumeMapper*, vtkImageData*, unsigned long, unsigned long) + 1606
> 7 0x7fcd4057e9b8 OmniConnect::UpdateVolume(unsigned long, double, OmniConnectVolumeData&, unsigned long, OmniConnectGenericArray*, unsigned long, OmniConnectGenericArray*, unsigned long) + 200
> 6 0x7fcd4057e2c8 /home/install_code/ParaView-5.9.1-MPI-Linux-Python3.8-64bit/bin/../lib/paraview-5.9/plugins/OmniverseConnector/../../../libOmniConnect-pv5.9.so.1(+0x402c8) [0x7fcd4057e2c8]
> 5 0x7fcd405a943e /home/install_code/ParaView-5.9.1-MPI-Linux-Python3.8-64bit/bin/../lib/paraview-5.9/plugins/OmniverseConnector/../../../libOmniConnect-pv5.9.so.1(+0x6b43e) [0x7fcd405a943e]
> 4 0x7fcd0a848b98 openvdb::v6_1::io::Stream::write(std::vector<std::shared_ptr<openvdb::v6_1::GridBase const>, std::allocator<std::shared_ptr<openvdb::v6_1::GridBase const> > > const&, openvdb::v6_1::MetaMap const&) const + 40
> 3 0x7fcd0a835eac openvdb::v6_1::io::Archive::write(std::ostream&, std::vector<std::shared_ptr<openvdb::v6_1::GridBase const>, std::allocator<std::shared_ptr<openvdb::v6_1::GridBase const> > > const&, bool, openvdb::v6_1::MetaMap const&) const + 108
> 2 0x7fcd0a8336f8 openvdb::v6_1::io::setDataCompression(std::ios_base&, unsigned int) + 72
> 1 0x7fcd0a830a00 openvdb::v6_1::io::StreamMetadata::setCompression(unsigned int) + 0
> 0 0x7fcdc6515090 /lib/x86_64-linux-gnu/libc.so.6(+0x43090) [0x7fcdc6515090]
> ( 70.346s) [paraview ] :0 FATL| Signal: SIGSEGV
> error: exception occurred: Segmentation fault
May I ask for some help to solve this problem or is it a known bug that is not solved yet? From the error message, I see it mentioned about the data type has a mismatch in floating point precision, is there something I can corrected it?
