Jon,
Thanks so much. Sorry for the confusion. I am using n51441.wav (I mentioned file.wav as a place holder for discussion). The SOC we are using is the Parker series. The software (vibrante-t186ref-linux) was provided as SDK to us.
./n51441.wav: RIFF (little-endian) data, WAVE audio, 6 channels 44100 Hz
We are using 3 I2S connections (I2S1 to connect to A2B/speaker as a slave, I2S3 to a radio tuner as a master, and I2S4 to a mic as a master). See the dts included earlier. The sound drivers are part of the vibrante-t186ref-linux.
I am attaching alsa-settings.txt (could not find a way to attach the file…)
[code]
Simple mixer control ‘DSPK1 Mux’,0
Capabilities: enum
Items: ‘None’ ‘ADMAIF1’ ‘ADMAIF2’ ‘ADMAIF3’ ‘ADMAIF4’ ‘ADMAIF5’ ‘ADMAIF6’ ‘ADMAIF7’ ‘ADMAIF8’ ‘ADMAIF9’ ‘ADMAIF10’ ‘ADMAIF11’ ‘ADMAIF12’ ‘ADMAIF13’ ‘ADMAIF14’ ‘ADMAIF15’ ‘ADMAIF16’ ‘I2S1’ ‘I2S2’ ‘I2S3’ ‘I2S4’ ‘I2S5’ ‘I2S6’ ‘SFC1’ ‘SFC2’ ‘SFC3’ ‘SFC4’ ‘MIXER1-1’ ‘MIXER1-2’ ‘MIXER1-3’ ‘MIXER1-4’ ‘MIXER1-5’ ‘AMX1’ ‘AMX2’ ‘AMX3’ ‘AMX4’ ‘ARAD1’ ‘SPDIF1-1’ ‘SPDIF1-2’ ‘AFC1’ ‘AFC2’ ‘AFC3’ ‘AFC4’ ‘AFC5’ ‘AFC6’ ‘OPE1’ ‘SPKPROT1’ ‘MVC1’ ‘MVC2’ ‘IQC1-1’ ‘IQC1-2’ ‘IQC2-1’ ‘IQC2-2’ ‘DMIC1’ ‘DMIC2’ ‘DMIC3’ ‘DMIC4’ ‘ADX1-1’ ‘ADX1-2’ ‘ADX1-3’ ‘ADX1-4’ ‘ADX2-1’ ‘ADX2-2’ ‘ADX2-3’ ‘ADX2-4’ ‘ADX3-1’ ‘ADX3-2’ ‘ADX3-3’ ‘ADX3-4’ ‘ADX4-1’ ‘ADX4-2’ ‘ADX4-3’ ‘ADX4-4’ ‘ADMAIF17’ ‘ADMAIF18’ ‘ADMAIF19’ ‘ADMAIF20’ ‘ASRC1-1’ ‘ASRC1-2’ ‘ASRC1-3’ ‘ASRC1-4’ ‘ASRC1-5’ ‘ASRC1-6’
Item0: ‘None’
Simple mixer control ‘DSPK2 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘I2S1 Loopback’,0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [off]
Simple mixer control ‘I2S1 Mux’,0
Capabilities: enum
Item0: ‘ADMAIF1’
Simple mixer control ‘I2S1 codec bit format’,0
Capabilities: enum
Items: ‘None’ ‘16’ ‘32’
Item0: ‘None’
Simple mixer control ‘I2S1 input bit format’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘I2S2 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘I2S3 Loopback’,0
Simple mixer control ‘I2S3 Mux’,0
Capabilities: enum
Item0: ‘AMX1’
Simple mixer control ‘I2S3 codec bit format’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘I2S3 input bit format’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘I2S4 Loopback’,0
Simple mixer control ‘I2S4 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘I2S4 codec bit format’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘I2S4 input bit format’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘I2S5 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘I2S6 Loopback’,0
Simple mixer control ‘I2S6 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘I2S6 codec bit format’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘I2S6 input bit format’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘Mixer Enable’,0
Simple mixer control ‘ADMA1 MUX’,0
Capabilities: enum
Items: ‘None’ ‘ADSP-FE1’ ‘ADSP-FE2’ ‘ADSP-FE3’ ‘ADSP-FE4’ ‘ADSP-FE5’ ‘ADSP-EAVB’ ‘ADSP-ADMAIF1’ ‘ADSP-ADMAIF2’ ‘ADSP-ADMAIF3’ ‘ADSP-ADMAIF4’ ‘ADSP-ADMAIF5’ ‘ADSP-ADMAIF6’ ‘ADSP-ADMAIF7’ ‘ADSP-ADMAIF8’ ‘ADSP-ADMAIF9’ ‘ADSP-ADMAIF10’ ‘ADSP-ADMAIF11’ ‘ADSP-ADMAIF12’ ‘ADSP-ADMAIF13’ ‘ADSP-ADMAIF14’ ‘ADSP-ADMAIF15’ ‘ADSP-ADMAIF16’ ‘ADSP-ADMAIF17’ ‘ADSP-ADMAIF18’ ‘ADSP-ADMAIF19’ ‘ADSP-ADMAIF20’ ‘APM-IN1’ ‘APM-IN2’ ‘APM-IN3’ ‘APM-IN4’ ‘APM-IN5’ ‘APM-IN6’ ‘APM-IN7’ ‘APM-IN8’ ‘APM-OUT1’ ‘APM-OUT2’ ‘APM-OUT3’ ‘APM-OUT4’ ‘APM-OUT5’ ‘APM-OUT6’ ‘APM-OUT7’ ‘APM-OUT8’ ‘ADMA1’ ‘ADMA2’ ‘ADMA3’ ‘ADMA4’ ‘ADMA5’ ‘ADMA6’ ‘ADMA7’ ‘ADMA8’ ‘ADMA9’ ‘ADMA10’ ‘REVERB’ ‘WIRE’ ‘EAVB_DMA_RX’ ‘AVB_DEPACK’ ‘EAVB_DMA_TX’ ‘AVB_PACK’ ‘PLUGIN7’ ‘PLUGIN8’ ‘PLUGIN9’ ‘PLUGIN10’
Item0: ‘None’
Simple mixer control ‘ADMA10 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMA2 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMA3 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMA4 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMA5 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMA6 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMA7 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMA8 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMA9 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMAIF1 Channels’,0
Capabilities: volume volume-joined
Capture channels: Mono
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF1 Mux’,0
Capabilities: enum
Item0: ‘ADX1-1’
Simple mixer control ‘ADMAIF10 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF10 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMAIF11 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF11 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMAIF12 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF12 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMAIF13 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF13 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMAIF14 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF14 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMAIF15 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF15 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMAIF16 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF16 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMAIF17 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF17 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMAIF18 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF18 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMAIF19 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF19 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMAIF2 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF2 Mux’,0
Capabilities: enum
Item0: ‘ADX1-2’
Simple mixer control ‘ADMAIF20 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF20 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMAIF3 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF3 Mux’,0
Capabilities: enum
Item0: ‘ADX1-3’
Simple mixer control ‘ADMAIF4 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF4 Mux’,0
Capabilities: enum
Item0: ‘ADX1-4’
Simple mixer control ‘ADMAIF5 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF5 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMAIF6 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF6 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMAIF7 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF7 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMAIF8 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF8 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADMAIF9 Channels’,0
Limits: 0 - 16
Mono: 0 [0%]
Simple mixer control ‘ADMAIF9 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP init’,0
Mono: Playback [on]
Simple mixer control ‘ADSP-ADMAIF1 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF10 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF11 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF12 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF13 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF14 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF15 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF16 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF17 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF18 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF19 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF2 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF20 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF3 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF4 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF5 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF6 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF7 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF8 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-ADMAIF9 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-EAVB MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-FE1 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-FE2 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-FE3 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-FE4 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADSP-FE5 MUX’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADX1 Mux’,0
Capabilities: enum
Item0: ‘I2S3’
Simple mixer control ‘ADX2 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADX3 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘ADX4 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘AFC1 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘AFC2 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘AFC3 Mux’,0
Capabilities: enum
Item0: ‘None’
Simple mixer control ‘AFC4 Mux’,0
Capabilities: enum
Items: ‘None’ ‘ADMAIF1’ ‘ADMAIF2’ ‘ADMAIF3’ ‘ADMAIF4’ ‘ADMAIF5’ ‘ADMAIF6’ ‘ADMAIF7’ ‘ADMAIF8’ ‘ADMAIF9’ ‘ADMAIF10’ ‘ADMAIF11’ ‘ADMAIF12’ ‘ADMAIF13’ ‘ADMAIF14’ ‘ADMAIF15’ ‘ADMAIF16’ ‘I2S1’ ‘I2S2’ ‘I2S3’ ‘I2S4’ ‘I2S5’ ‘I2S6’ ‘SFC1’ ‘SFC2’ ‘SFC3’ ‘SFC4’ ‘MIXER1-1’ ‘MIXER1-2’ ‘MIXER1-3’ ‘MIXER1-4’ ‘MIXER1-5’ ‘AMX1’ ‘AMX2’ ‘AMX3’ ‘AMX4’ ‘ARAD1’ ‘SPDIF1-1’ ‘SPDIF1-2’ ‘AFC1’ ‘AFC2’ ‘AFC3’ ‘AFC4’ ‘AFC5’ ‘AFC6’ ‘OPE1’ ‘SPKPROT1’ ‘MVC1’ ‘MVC2’ ‘IQC1-1’ ‘IQC1-2’ ‘IQC2-1’ ‘IQC2-2’ ‘DMIC1’ ‘DMIC2’ ‘DMIC3’ ‘DMIC4’ ‘ADX1-1’ ‘ADX1-2’ ‘ADX1-3’ ‘ADX1-4’ ‘ADX2-1’ ‘ADX2-2’ ‘ADX2-3’ ‘ADX2-4’ ‘ADX3-1’ ‘ADX3-2’ ‘ADX3-3’ ‘ADX3-4’ 'ADX4-1
