I have the following code example which gives an error when compiled as a host code but does not compile as a device code.
#define GPU
#include <cstdint>
template<uint32_t T>
struct A{
struct In
template <uint32_t T>
__host__ __device__ void get(A<T>& ret) const
template <typename T, uint32_t F>
__host__ __device__ void test(uint8_t out[], T in)
A<F> a;
in.get<F>(a);
__global__ void test_run() {
test<In, 4>(nullptr, In{}) ;
int main() {
#ifdef GPU
test_run<<<1,1>>>();
#else
test<In, 4>(nullptr, In{});
#endif
run on godbolt
(comment #define GPU
for host version)
Is this a parser error? I could see that it does not compile on g++ as well. But in that case, I would expect it to fail on device version as well.
Update:
Found that adding template
to the function call on the object of the template parameter would fix the compile issue on host. But still, I wonder why it parses differently on device version.
