I have a plugin CDCGreedyDecoder with two inputs, the last layer shown in the attached picture (the last layer).
So the layer has two inputs and one output.
Onnx-TensorRT parser is used to parse the plugin to TensorRT in the file TensorRT/parsers/onnx/builtin_op_importers.cpp as follows.
DEFINE_BUILTIN_OP_IMPORTER(CTCGreedyDecoder)
//const int nbInputs = node.input().size();
//const int nbOutputs = node.output().size();
//LOG_ERROR("nbInputs: " << nbInputs );
//LOG_ERROR("nbOutputs: " << nbOutputs );
//ASSERT(inputs.at(1).is_weights(), ErrorCode::kUNSUPPORTED_NODE);
//ASSERT(inputs.at(2).is_weights(), ErrorCode::kUNSUPPORTED_NODE);
nvinfer1::ITensor* tensorPtr = &convertToTensor(inputs.at(0), ctx);
int nbDims = tensorPtr->getDimensions().nbDims;
ASSERT(nbDims >= 3 && nbDims <= 4 && "TensorRT only supports InstanceNormalization on 3D or 4D tensors!", ErrorCode::kUNSUPPORTED_NODE);
OnnxAttrs attrs(node, ctx);
// Populate instanceNormalization plugin properties.
const std::string pluginName = "CTCGreedyDecoder_TRT";
const std::string pluginVersion = "1";
std::vector<nvinfer1::PluginField> f;
// Create plugin from registry
nvinfer1::IPluginV2* plugin = importPluginFromRegistry(ctx, pluginName, pluginVersion, node.name(), f);
ASSERT(plugin != nullptr && "CTCGreedyDecoder plugin was not found in the plugin registry!", ErrorCode::kUNSUPPORTED_NODE);
auto* layer = ctx->network()->addPluginV2(&tensorPtr, 1, *plugin);
ctx->registerLayer(layer, node.name());
RETURN_FIRST_OUTPUT(layer);
Print out number of inputs and output and found out input/output numbers at CDCGreedyDecoder are as follows.
[TRT]: /home/xavier/TensorRT/parsers/onnx/builtin_op_importers.cpp:1567: nbInputs:2 [TRT]: /home/xavier/TensorRT/parsers/onnx/builtin_op_importers.cpp:1568: nbOutputs: 1
When converting onnx model to engine, number of inputs 1
is observed at CDCGreedyDecoder plugin’s method
void configurePlugin(const DynamicPluginTensorDesc* in, int nbInput, const DynamicPluginTensorDesc* out, int nbOutput) override.
What is wrong in my implementation of onnx-tensorrt parser implementation?
DEFINE_BUILTIN_OP_IMPORTER(CTCGreedyDecoder) parser is shown above.
