Parsing Uff file works TensorRT 5.1.2.2 and not in TensorRT 5.0
I modified the sampleUffMNIST example from TensorRT to work with an Uff file which I created from a frozen tensorflow graph. In TensorRT 5.1.2.2 this works perfectly.
In TensorRT 5.0 I get 2 problems:
In TensorRT version 5.1.2.2 I can use the following for registering the Input:
parser->registerInput("image", Dims3(480, 640, 3), nvuffparser::UffInputOrder::kNHWC);
With TensorRT 5.0 I get:
ERROR: [...]: kernel weights has count 1728 but 276480 was expected
which can be explained by registerInput expecting the number of channels as first dimension. I can’t find any remark in the release notes that the order of the dimensions changing between 5.0 and 5.1.2.2
No matter if I use:
parser->registerInput("image", Dims3(3, 640, 480), nvuffparser::UffInputOrder::kNHWC);
parser->registerInput("image", Dims3(3, 640, 480), nvuffparser::UffInputOrder::kNCHW);
parser->registerInput("image", Dims3(3, 480, 640), nvuffparser::UffInputOrder::kNHWC);
parser->registerInput("image", Dims3(3, 480, 640), nvuffparser::UffInputOrder::kNCHW);
in Version 5.0 the net detects nothing
Do I need to change my input in a way that it fits TensorRT 5.0?
