Hi everyone,
I’m working on project of Lane detection models, where i need to divide a pytorch defined model in many component and each component will be executed on an edge device in order to improve latency and memory consumption ( See attached figure ) in my case i have jetson tx2 and jetson agx.
My questions are :
- Is there a method to easily communicate data between the two devices with a minimum time of data transmission possible.
- Is there framwork to divide a pytorch model and get results of a specific layer
- what is the best struture to store the data that we want to send to another device
And finally I have another question a little off topic: is it possible to run a lane marker detection model on the camera of the jetson tx2 in real time, I tried with the LaneATT model but I could not make it work in real time.
thank you in advance.
