Hi all,
As described I am able to compile and start the particles example, however when I get it running it is running at 0.1 fps. I am running Fedora 10 operating system using the Fedora 9 drivers.
Thanks in advance
Hi all,
Thanks in advance
Please generate and attach an nvidia-bug-report.log
Uhm, I am sooo newb. How do I do that?
in a terminal run nvidia-bug-report.sh (from memory, so type nvidia, then push the TAB button, you should see a list of all programs that start with nvidia then).
This script will generate a file in the current directory
Ok, I will have a the file posted by 10am.
Here is the log as promised
you will have to rename the file to .txt, the forum refuses .log extensions…
