Pascal L1 cache
The Volta L1 data cache has 128 byte cache lines divided into 4 sectors. For local and global accesses the tag stage can compare all 32 threads at a time. The tag stage can look up 4 tags per cycle resolving a maximum of 16 sectors (4 tags x 4 sectors). On miss the cache will only fetch the unique 32 byte sectors that missed. The full cache line is not automatically fetched from L2.
The Maxwell/Pascal L1 data cache had similar tag stage performance but local and global instructions were broken into multiple requests prior to the tag lookup
  • <=32-bit 8 threads/request
  • 64-bit 4 threads/request
  • 128-bit 2 threads/request
