Hi all,
When I try to pass a reference to an array to a kernel, cudafe(?) fails with an internal error.
The code below triggers this behaviour on my system:
template<unsigned int chunk_levels, unsigned int layers, class T>
__global__ void
foo( const unsigned int (&offsets)[layers] )
int main()
 unsigned int offsets[3];
 foo<3,3,unsigned int><<<dim3(42,1),dim3(64,1)>>>( offsets );
 return 0;
When I try to compile it:
[font=“Courier”]modesty ~ $ nvcc -V
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2007 NVIDIA Corporation
Built on Tue_Jun_10_05:42:45_PDT_2008
Cuda compilation tools, release 1.1, V0.2.1221
modesty ~ $ nvcc reproduce.cu
reproduce.cu(7): internal error: assertion failed at: “/home/buildmeister/nightly/rel/gpgpu/toolkit/r2.0/compiler/edg/EDG_3.9/src/il_to_str.c”, line 4188
1 catastrophic error detected in the compilation of “/tmp/tmpxft_00002cbb_00000000-4_reproduce.cpp1.ii”.
Compilation aborted.
nvcc error : ‘cudafe’ died due to signal 6
modesty ~ $ [/font]
I run CUDA 2.0 beta2 on driver rel 177.13 on a gentoo linux with gcc 4.1.2.
Thanks,
Chris
Edit: I know that the code is insane. :)
