I have a CUDA kernel that takes in (C++) template argument for important information such the size of an array I want to initialize in the kernel stack. It used to work fine when my host program is written in C/C++ that I can easily pass it as a template argument. For example:
template global void foo()
double W[numberOfTaps];
Now I moved to MATLAB’s Parallel Computation Toolbox, where I can compile my CUDA kernel into PTX and call it from MATLAB (where my host code is):
kernel=parallel.gpu.CUDAKernel(‘foo.ptx’, ‘foo.cu’);
feval(kernel);
The problem is that there’s no way to enter the template arguments from MATLAB. Any ideas I can use templates to pass template arguments into the kernel from non C/C++ host environment?
feval(kernel);
Templates are instantiated by nvcc as part of the top level C++ compilation. This happens well before PTX is ever generated. They’re not runtime arguments, they’re compile-only code definitions that are visible only at compile time.
An ugly and unportable workaround might be to write a little Matlab wrapper, having Matlab use a system call to nvcc itself, passing your template arguments as -D define switches in the nvcc command line, then using the generated PTX in Matlab. Ugly but maybe it’d work.
I thought about this too, but I have trouble figuring out how to define values from the -D switch. I’ve defined macro variables before (“-DMACROVAR” is translates to “define MACROVAR”), but how can I make it assume a value that’s equivalent to “define MACROVAR 17”?
It’s probably like GCC, where you use something like “nvcc -D MACROVAR=17”
It may be possible (or necessary) to concatenate the definition with the D symbol, like “nvcc -DMACROVAR=17”
A quick test should tell you if so, I’m not on my dev machine so I can’t try it.
You may need to use single or double quotes (depending on your shell and OS) if the macro definition has spaces or escape characters.
