GPU/T4
• DeepStream Version
DeepStream-6.0
NVIDIA-SMI 470.94 Driver Version: 470.94 CUDA Version: 11.4
bugs
when I put the same type of nvds meta multiple times before nvv4l2decoder and try to probe nvv4l2decoder src. I can only get meta mixed but regularly. For example, I first send an output with many custom meta, but the src probe won’t be triggered. the second will, only get mixed the first custom meta and the second.
here is my pipeline.dot
Before nvv4l2decoder, I used rtph264depay and manually set caps to nal instead of au.
here is my code
#include <gst/gst.h>
#include <string>
#define GST_CUSTOM_META (nvds_get_user_meta_type("GST_CUSTOM_META"))
class CustomMeta
public:
CustomMeta(){}
CustomMeta(const CustomMeta& meta)
this->nums = meta.nums;
public:
int nums;
static gpointer custom_copy_meta_func(gpointer data,gpointer user_data)
CustomMeta* src_meta = (CustomMeta*)data;
CustomMeta* dst_meta = new CustomMeta(*src_meta);
return dst_meta;
static void custom_release_meta_func(gpointer data,gpointer user_data)
CustomMeta* meta = (CustomMeta*)data;
if(meta)
delete meta;
static gpointer custom_gst_to_nvds_transform_func(gpointer data,gpointer user_data)
NvDsUserMeta* user_meta = (NvDsUserMeta*)data;
CustomMeta* meta = (CustomMeta*)user_meta->user_meta_data;
CustomMeta* dst_meta = (CustomMeta*) custom_copy_meta_func(meta,NULL);
return dst_meta;
static void custom_gst_to_nvds_release_func(gpointer data, gpointer user_data)
CustomMeta* timestamp_meta = (CustomMeta*)user_meta->user_meta_data;
custom_release_meta_func(timestamp_meta,NULL);
int nums = 0;
static void pad_added_handler_F (GstElement *src, GstPad *new_pad, GstPad* sink_pad)
// GstPad* sink_pad = gst_element_get_static_pad(u_data->queue,"sink");
GstPadLinkReturn ret;
const gchar *new_pad_type = NULL;
g_print ("Received new pad '%s' from '%s':\n", GST_PAD_NAME (new_pad), GST_ELEMENT_NAME (src));
/* If our converter is already linked, we have nothing to do here */
if (gst_pad_is_linked (sink_pad)) {
g_print ("We are already linked. Ignoring.\n");
goto exit;
ret = gst_pad_link(new_pad,sink_pad);
if (GST_PAD_LINK_FAILED (ret)) {
g_print ("Type is '%s' but link failed.\n", new_pad_type);
} else {
g_print ("Link succeeded (type '%s').\n", new_pad_type);
exit:
gst_object_unref (sink_pad);
return;
static GstPadProbeReturn insert_custom_meta(GstPad*pad, GstPadProbeInfo* info, gpointer user_data)
GstBuffer * buffer = GST_PAD_PROBE_INFO_BUFFER(info);
buffer = gst_buffer_make_writable(buffer);
CustomMeta* customMeta = new CustomMeta();
NvDsMeta* meta = NULL;
meta = gst_buffer_add_nvds_meta(buffer, custom_meta, NULL, custom_copy_meta_func,
custom_release_meta_func);
meta->meta_type = GST_CUSTOM_META;
meta->gst_to_nvds_meta_transform_func = custom_gst_to_nvds_transform_func;
meta->gst_to_nvds_meta_release_func = custom_gst_to_nvds_release_func;
customMeta->nums = nums++;
return GST_PAD_PROBE_OK;
static GstPadProbeReturn get_custom_meta(GstPad*pad, GstPadProbeInfo* info, gpointer user_data)
GstMeta* gst_meta = NULL;
NvDsMeta * nvds_meta = NULL;
gpointer state = NULL;
while(gst_meta = gst_buffer_iterate_meta(buffer,&state))
nvds_meta = (NvDsMeta*)gst_meta;
if(nvds_meta->meta_type = GST_CUSTOM_META)
CustomMeta* meta = (CustomMeta*)nvds_meta->meta_data;
GST_INFO("timestamp from decoder %ld",meta->nums);
int main() {
std::string uri = "rtsp://172.21.30.204:554/rtp/34020000001320001008/34020000001320001008/SIMPLE";
GstElement * pipeline = gst_pipeline_new("test-pipeline");
GstElement * source = gst_element_factory_make("urisourcebin","source");
GstElement * sink = gst_element_factory_make("fakesink","sink");
GstElement * depay = gst_element_factory_make("rtph264depay","depay-0");
GstElement * capsfilter = gst_element_factory_make("capsfilter","filter-0");
GstElement * nvstreammux = gst_element_factory_make("nvstreammux","mux");
GstElement * parser = gst_element_factory_make("h264parse","parse");
GstElement * decoder = gst_element_factory_make("nvv4l2decoder","decoder");
gst_bin_add_many(GST_BIN(pipeline),source,sink,depay,capsfilter,parser,nvstreammux,decoder,NULL);
gst_element_link_many(depay, capsfilter, parser, decoder,NULL);
GstPad* depay_src_pad = gst_element_get_static_pad(depay,"src");
GstPad* depay_sink_pad = gst_element_get_static_pad(depay,"sink");
GstPad* decoder_src_pad = gst_element_get_static_pad(decoder,"src");
GstPad* mux_sink_pad = gst_element_get_request_pad(nvstreammux,"sink_0");
GstPad* mux_src_pad = gst_element_get_static_pad(nvstreammux,"src");
gst_pad_link(decoder_src_pad,mux_sink_pad);
gst_element_link(nvstreammux,sink);
g_signal_connect(source,"pad-added",G_CALLBACK(pad_added_handler_F),depay_sink_pad);
g_object_set(source,"uri",uri.c_str(),NULL);
g_object_set(nvstreammux,"width",1920,"height",1080,"batch-size",1,NULL);
GstCaps *caps = gst_caps_new_simple ("video/x-h264",
"stream-format", G_TYPE_STRING, "byte-stream",
"alignment", G_TYPE_STRING, "nal",
NULL);
g_object_set(capsfilter,"caps",caps,NULL);
gst_pad_add_probe(depay_src_pad,GST_PAD_PROBE_TYPE_BUFFER,GstPadProbeCallback(insert_custom_meta),NULL,NULL);
gst_pad_add_probe(decoder_src_pad,GST_PAD_PROBE_TYPE_BUFFER,GstPadProbeCallback(get_custom_meta),NULL,NULL);
gst_object_unref(depay_src_pad);
gst_object_unref(depay_sink_pad);
gst_object_unref(decoder_src_pad);
gst_object_unref(mux_sink_pad);
gst_object_unref(mux_src_pad);
gst_element_set_state(pipeline,GST_STATE_PLAYING);
GMainLoop *mainLoop;
mainLoop = g_main_loop_new(NULL,FALSE);
g_main_loop_run(mainLoop);
gst_element_set_state(pipeline,GST_STATE_NULL);
gst_object_unref(pipeline);
return 0;
