Passing a vector of structure to the device I need help about how to pass a std::vector<structure
I’ve got a problem. I’d like to pass a vector of structure from the host to the device, in order to do some computation on it, and then pass it back to the host.
I’m using a std::vector of a custom structure. Here is my code :
#include <iostream>
#include <string>
#include <vector>
#include <cuda.h>
using namespace std;
//STRUCTURE DEFINITION
struct prgm_structure
	string name;
	int fitness;
//VECTOR DEFINITION
typedef vector<prgm_structure> prgm_vector;
//KERNELL FUNCTION
__global__ void calcul_fitness_GPU_Device(prgm_vector* population)
	int fitness;
	fitness = population[threadIdx.x].fitness;
//MAIN FUNCTION
int main()
	//Creation and initialisation of the vector "population_Host"
	prgm_vector population_Host;
	initialisation_population(population_Host);
	//Allocation and load of the vector "population_Device"
	prgm_vector* population_Device;
	int size = population_Host.size() * sizeof(prgm_structure);
	cudaMalloc((void**)&population_Device, size);
	cudaMemcpy(population_Device, &population_Host, size, cudaMemcpyHostToDevice);
	//Call of the kernell function
	dim3 dimBlock(16);
	dim3 dimGrid(1);
	calcul_fitness_GPU_Device<<<dimGrid, dimBlock>>>(population_Device);
This code doesn’t compile. I don’t manage to access the elements of the vector once in the kernell. I got an error at this line in the kernell :
The error is :
If change this line to :
fitness = population.at(threadIdx.x).fitness;
The error become :
And if i change it again to :
fitness = population->at(threadIdx.x).fitness;
Then the error become :
I don’t understand, and i’ve no more idea… :">
Is it possible to pass a vector of structure to the device kernell? If yes, does somebody know how to correct my code?
Thanks External Media
An std::vector, unless you use a custom allocator, only holds host memory. Use a pointer instead, or use the vector class in the CUPP project
//VECTOR DEFINITION
typedef vector<prgm_structure> prgm_vector;  // for host memory only!!!
//KERNELL FUNCTION
__global__ void calcul_fitness_GPU_Device(prgm_structure* population)
	int fitness = population[threadIdx.x].fitness;
//MAIN FUNCTION
int main()
	prgm_structure* population_Device;
	cudaMemcpy(population_Device, &population_Host[0], size, cudaMemcpyHostToDevice);
	dim3 dimBlock(16);
	dim3 dimGrid(1);
You should also try to make sure you are not accessing memory outside what you allocated.
Thanks for your reply.
How would you do using a pointer instead of a vector? I already use a pointer, don’t I?
The address of the first element in the vector, not the address of the vector itself, is the pointer to the underlying array that you can memcopy. In *rocha’s code, it’s this part
Note taking address of the [0] element
OK, thanks. I didn’t noticed this change
I will try this.
Thanks for your help
//KERNELL FUNCTION
global void calcul_fitness_GPU_Device(prgm_structure* population)
I suposse you are wrong here. The structure was not needed to be passed instead the whole vector was to be passed.
No it works. No need to pass the whole vector : the adress of its first element is enough. If you know the adress of the first element, you can access the following ones…
Just stick with ANSI-C:
typedef struct prgm_structure
	string name;
	int fitness;
} prgm_vector;
or
	string name;
	int fitness;
//VECTOR DEFINITION
typedef struct prgm_structure prgm_vector;
