hi guys i want to create a matrix from a file in the host, then load that values in the device memory and work with them in a kernel… how can i do it? i’m a noob, and i’m a bit confused…
i got runtime error calling the g_evolve function… probably because from device functions, d_a seems to be not initialized…
from main:
float* d_a; //by specifics, i can’t change that
pass(d_a,problemDimension,functionID);
g_evolve(functionID,d_a);
where:
host void pass (float* d_a, unsigned int problemDimension, unsigned int functionID) {
if (functionID==9) {
float* h_a;
size_t matrixSize = problemDimensionproblemDimensionsizeof(float);
h_a = (float )malloc(matrixSize); //they’re vectors because cudaMemCpy doesn’t work with matrix
matrixLoad(h_a,problemDimension); //load from file
cudaMalloc((void*)&d_a,matrixSize);
cudaMemcpy(d_a,h_a,matrixSize,cudaMemcpyHostToDevice);
free(h_a)
g_init(functionID,d_a);
static global void g_init(unsigned int functionID, float* d_a) {
//kernel work with matrix d_a…
static global void g_evolve(unsigned int functionID, float* d_a) {
any help/ideas? i’m really noob to cuda!!!
thanks in advance
Enrico
P.S
i’ve read this thread: http://forums.nvidia.com/index.php?showtopic=192574 but i still don’t understand
