I have a kernel which passes 3 arrays, the first array d_A1 has no data and is used only to write back data, the other two arrays d_D1 and d_ST1 have data.
The size of the first array is:
d_A1[13000000]
The size of the second array is:
d_D1[421]
The size of the third array is:
d_ST1[21]
N is 13000000
TestArray<<>>(d_A1,N, d_D1, d_ST1);
Now I want only pass the data of d_D1[421] and d_ST1[21] to shared arrays so I created the shared arrays as:
global void TestArray(int* A1, unsigned int N, int* D1, unsigned int* ST1)
unsigned int align(16) tid = threadIdx.x;
unsigned int align(16) idx = __umul24(blockDim.x, blockIdx.x) + threadIdx.x;
shared unsigned int align(16) s_D1[441]; //Shared array for d_D1
shared unsigned int align(16) s_ST1[21]; //Shared array for d_ST1
if (idx < N) //13000000
Q. How do I pass the data of d_D1[441] and d_ST1[21] to s_D1[441] and s_ST1[21]?
I tried:
while (idx < 441)
s_D1[tid] = d_D1[idx]
__syncthreads();
while (idx < 21)
s_ST1[tid] = d_ST1[idx]
__syncthreads();
but the computer freezes and I have to restart it.
I also tried one at the time,namely, only the fist
while and then only the second while, with no luck.
If I use the global memory, namely, d_D1, d_ST1 everything works.
So the question is:
How do you pass data to a shared variable/array when the size of the array is not N?
} //End of kernel processing
