Passing generator state by pointer
Is the following code correct when passing the random generator state by reference in function CalculateValue(curandState *localStat) and GetExponential(curandState *localState)?
__device__ double GetExponential(curandState *localState)
	double u1 = curand_uniform_double(localState);
__device__  double CalculateValue(curandState *localStat)
      double x = GetExponential(localState);
return x;
__global__ void RunMonteCarloKernel(curandState *state, double *results)
	int i = threadIdx.x + blockIdx.x * blockDim.x;
	/* Copy state to local memory for efficiency */
	curandState localState = state[threadIdx.x + blockIdx.x * blockDim.x];
	results[i] = CalculateValue(&localState);
	/* Copy state back to global memory */
	state[threadIdx.x + blockIdx.x * blockDim.x] = localState;
__global__ void setup_kernel(curandState *state)
	/* Each thread gets different seed, a different sequence number, no offset */
	curand_init(i, i, 0, &state[i]);
int main(void)
        double *devResults;
	curandState *devStates;
	/* Allocate space for prng states on device */
	CUDA_CALL(cudaMalloc((void **)&devStates, totalThreads * sizeof(curandState)));
/* Setup prng states */
       setup_kernel<<<totalBlocks, threadsPerBlock>>>(devStates);
	for(int i=0; i< 1000; i++)
		RunMonteCarloKernel(devStates, devResults);
return x;
int main(void)
        double *devResults;
The function GetExponential should have a return value. The function RunMonteCarloKernel is a global function, which means it should be called using the triple angle bracket syntax <<<>>>. The pass-by-pointer code looks OK External Image
As a performance note, the code has each thread calculate one output value. It will be much faster to loop and have each thread calculate many result values.
Thanks. Very helpful.
