• Hardware Platform (Jetson / GPU) dGPU
• DeepStream Version 6.0
• TensorRT Version
• Issue Type( questions, new requirements, bugs) question
I am using deepstream-test1 reference graph for Graph Composer. The first component of the pipeline is nvidia::deepstream::NvDsSingleSrcInput. Source uri is one of the properties. I am able to set this property in the designer or in the parameters.yaml file. I am building the container with Container Builder using ds_test1_container_builder_dgpu.yaml. I would like to be able to specify the value of the URI property on the “docker run” command line and when I create the container with docker API. Is this possible at the moment or the only way is to modify the parameters.yaml file? Where could I find more details about ENTRYPOINT functionality in Container Builder Configuration?
