• Hardware Platform (Jetson / GPU) RTX 2060 • DeepStream Version 5.0 • JetPack Version (valid for Jetson only) • TensorRT Version 7.1 • NVIDIA GPU Driver Version (valid for GPU only) 10.2 • Issue Type( questions, new requirements, bugs) Requirements • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
I want to pass a value to Custom Object Detection function which I have implemented in library and configured in deepstream using parse-bbox-func-name and custom-lib-path.
I want to include some values dynamically here.
I am using the deepstream-test3 for reference.
How can I achieve that from deepstream_app.c
I am running multiple models on multiple input streams and I want to choose which values to choose dynamically here, so looking for a way to pass information from the main file to the custom library.
I have written a custom parser function. This Parser function has to configure some parameters based on input stream,
The only input data I get here is through the function
Currently I think you need to achieve that following deepstream-infer-tensor-meta-test.
Because you cannot pass the params like id you mentioned via current post parser function
